clock and radio problem! so confusing...
1990 Accord EXR
Original situation:
I have no radio, the vehicles wire harness is cut, and my clock works...
New Situation:
Solder on a new wire harness. plugged in my deck, and now i have sound!
but now the clock does not exist
also, everytime the car is off for longer than 15 mins or so, the radio completely resets itself, all the preset stations are gone!
anybody?
Original situation:
New Situation:
anybody?
i checked the fuses..but i will double check incase i overlooked one....
but what fuse would cuase the problem?
if one of the radio fuses were misssing...woudlnt that mean that the radio woudlnt work?
Not necessarily.
I had a weird similar situation when I did exactly what you did, soldered back on a harness.
Mine was called "Backup Radio/Antenna" or something along those lines.
Take a real good look at both interior and under-hood panels. I looked at them like 3 times before I asked HT and sure enough I missed it.
ah yes! you guys are correct....
i noticed the 7.5 amp fuse was blown underneath the hood..so i will replace that and let you know if i get my clock back...and if the radio doesnt reset everytime...
on a sdie note...
rght beneath the 7.5 amp radio fuse...there is a fuse for a "small light" (as it is listed on the fuse box panel)...what is that for...
its suppose to have 20 amps...but mine only has 15amp....i will also change that to 20....but what is it for?
on a sdie note...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy »</TD></TR><TR><TD CLASS="quote">ah yes! you guys are correct....
on a sdie note...
its suppose to have 20 amps...but mine only has 15amp....i will also change that to 20....but what is it for?</TD></TR></TABLE>
it has to do with the parking lights i do believe... maybe interior lights too.
on a sdie note...
turbotime
May 29, 2005 08:27 PM
