My latest Vitara build
Old Dec 20, 2007 | 06:25 AM
homemadeturbo's Avatar
Default My latest Vitara build
Pretty standard TT/Vitara setup on a z6. I'm currently running a .48/.60 T-bird T3 and am going to have some fun with it for a bit before I get a bigger turbo and intercooler. I haven't tuned it yet but I'm only shooting for 300 whp, I'm sure I'll up the boost at some point and test it's limits since I have a spare block now.
Specs:
'92 dx sedan
Z6 block/y5 vtec-e head
75mm Vitara pistons
OEM main/rod bearings
TT rods (one rod needed machining to fit the wrist pin)
TT 660cc injectors
Stealthmode oil lines/firewall kit
Supposed prototype Blur manifold, feels pretty expletivein solid
TiAl 38mm wastegate
JRC 6" intercooler (for now)
Walbro 255lph LP in-tank pump
.48/.60 60 trim T3
Greddy Profec Type S EBC
1G DSM BOV
2.5" charge piping, downpipe, and exhaust. Exhaust consists of a 2' long cherry bomb for a resonator and a generic turbo muffler.
Obligatory rod/piston shot
Block notched
I got shiny instead of flat aluminum engine paint on accident and just said expletive it. My block is mexichromed out :8
Boost, oil pressure, boost control
The closest button to the shifter is hooked up to the EBC to switch between high and low boost settings. Right before I shift into 3rd I hit it with the heel of my hand to switch to high boost. Lower **** is the gain control for the sub amp.
I knew my intercooler piping had begun to rust even after I painted it, it's mild steel and has been through 2 Wisconsin winters. I did NOT know that it was all rusted on the inside, maybe even worse than the outside. It ran great and I had no idea it was this bad; glad I saw it before my engine ingested rust flakes.
So I picked up an eBay aluminum piping kit for $100 shipped, not a bad deal. expletive some rust.
Al tubing installed, I reused the 45 off the throttle body with the bov flange on it because I'm lazy
And a little before and after shot
[/quote]
Old Dec 20, 2007 | 07:16 AM
supergenius's Avatar
Default Re: My latest Vitara build (homemadeturbo)
Yous gonna get raped son......
hahahaha
HMT fo Lyfe
Old Dec 20, 2007 | 07:46 AM
m R g S r's Avatar
Default Re: My latest Vitara build (supergenius)
why its not that bad......i mean the one fab manifold doesn't have the best rep, but its not SSAC....and the piping....well i'm sure it could have been done much cleaner with a little more time into it. . . . but overall looks good...should make decent power.
Old Dec 20, 2007 | 07:51 AM
Default Re: My latest Vitara build (m R g S r)
Hey the piping is perfect, just that one 45 off the TB has some surface rust
Old Dec 20, 2007 | 08:48 AM
welfarepc's Avatar
did you get the block bored? what size vitaras? what kind of vitaras?
pure garage hone?
hehe i wana do a ghetto vitara soon
Old Dec 20, 2007 | 08:57 AM
Default Re: (welfarepc)
It says that in my post, reading > you
75mm. I just had the machine shop hot tank and hone the block and hone the one small rod end for the wrist pin.
Old Dec 20, 2007 | 09:19 AM
eg:R's Avatar
any piston slap on the pistons?
Old Dec 20, 2007 | 09:41 AM
Default Re: (eg:R)
Of course
Old Dec 20, 2007 | 09:57 AM
Default Re: (homemadeturbo)
is yous goin get raped???
Old Dec 20, 2007 | 10:06 AM
Default Re: (supergenius)
Some mod yelled at me for having the word "raped" in my avatar so I had to change it
BDVT smokes rocks son, and tires
Old Dec 20, 2007 | 10:17 AM
HiProfile's Avatar
So what are your goals for power? I wouldn't be happy with anything less than 18psi on that snail
Old Dec 20, 2007 | 10:22 AM
Default Re: (HiProfile)
My goal is 300 whp which shouldn't be hard. That's really pushing it with this turbo, but I am upgrading to a t3/t4 sometime next year. Right now I have it tuned up to 12 psi due to there constantly being snow on the ground and not getting traction and it's already a ton of fun
Old Dec 20, 2007 | 03:35 PM
turbo sol's Avatar
how do yo ulike the vtec-e head with the build?
i have the option for either z6 or the vtec E, but I am gonna use the z6
Old Dec 20, 2007 | 05:49 PM
Default Re: (turbo sol)
The y5 head is great. 45 mpg highway
Old Dec 20, 2007 | 06:22 PM
Drew Peacock's Avatar
How much are the rods? Niceish setup.
Old Dec 20, 2007 | 06:38 PM
Default Re: (Drew Peacock)
$250
Old Dec 21, 2007 | 03:59 PM
JaredKaragen's Avatar
You say that manifold isn't SSAC;
http://www.ssautochrome.com
look 4 yourself.
SSAC is a distributor/retailer, not a vendor.
Those manifolds are not manufactured in Taiwan like the other products they have; I believe they may be made in Mexico; I have not been able to find out the vendor info on them yet.
Just compare this manifold to any of SSAC's products: you can see that it was welded, not just touched by a TiG, and it is of a much heavier and better material.
Rated between 500 and 800 Deg F. Not too shabby; considering the manifold itself does not maintain a 800+ temp for long unless you would be at max boost on a 5th gear pull for 5-10 min.
Old Dec 21, 2007 | 04:54 PM
Default Re: (JaredKaragen)
It's made of thick piping and the welds look good, it feels very solid.
Old Dec 21, 2007 | 08:10 PM
PiMpIn's Avatar
HMT ROCKS
Old Dec 21, 2007 | 10:21 PM
quicksilver1689's Avatar
i ♥ snails
i got a homemade turbo [racial pejorative], thats where it counts, i got them polyurethane motor mounts.
Old Dec 21, 2007 | 10:37 PM
Default Re: (quicksilver1689)
I GOT YOUR MOTHER expletiveIN PINK SLIP BIIIITCH!!!!!
Stealthmode MCPL and Tre west for The Win bitches....
Old Dec 22, 2007 | 04:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">i got a homemade turbo [racial pejorative], thats where it counts, i got them polyurethane motor mounts.</TD></TR></TABLE>
That was a sad attempt
Old Dec 22, 2007 | 09:19 PM
welfarepc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homemadeturbo &raquo;</TD></TR><TR><TD CLASS="quote">reading &gt; you </TD></TR></TABLE>
hehe so true
96Dc2 GSR
Jun 28, 2011 07:44 PM
EK FLY
Aug 22, 2006 03:24 PM
5thgencivic
Aug 13, 2003 10:32 PM
xXxS_SxXx
Jan 6, 2003 07:21 PM
