suspension
i want suspension for my sedan but can't decide between springs or coilovers. i dont want to go cheap neither expensive. i was thinking about ground control coilover sleeves on kyb gr-2 or kyb gr-2 with eibach springs. i want a comfortable smooth ride. would the coilover be to stiff ????
whatever the spring is, make sure it's eibach. best, most consistent springs in the world.
ground control coilovers use eibach springs and coupled with koni adjustable struts you have a real winner.
make sure you order the GC's AFTER you talk to GC about what rate combo you need.
i did shocks/springs seperate and it took forever to compress and decompress and repeat, coilovers are much much easier.
