burning off oil in cylinders
Old Dec 19, 2007 | 05:39 PM
delspool's Avatar
Default burning off oil in cylinders
i just started a car with a motor that had been sitting for ~3 years. about a year ago i had put a cap full of oil in each cylinder to try to preserve it the best i could. when i started it yesterday it smoked pretty good and you could tell that it was being burnt off
now, its been ran for about 30-45 minutes total and there is still some slight whitish smoke coming out.
do you guys think this could be normal? or do i probably have some engine problems?
btw, i do have check engine codes 16 & 43 but those are fuel codes so i dont think that has much to do with the smoke
Old Dec 20, 2007 | 05:50 AM
non-VTEC's Avatar
Default Re: burning off oil in cylinders (delspool)
put some fresh fuel in it and drive it around for a bit. the smoke should clear up.
if not do a compression and leakdown test.
Old Dec 20, 2007 | 02:33 PM
Perfectionist's Avatar
Regarding your code 16...
That code sets whenever there is a break in the electrical circuit for the injectors. It starts at the battery, through fuses and ignition switch, main relay, injector resisitors (if so equiped), injector coils, a lot of connectors and wire, and ends at the ECU.
Just a heads up.
Old Dec 20, 2007 | 03:15 PM
delspool's Avatar
Default Re: burning off oil in cylinders (Perfectionist)
thanks for the info
damnit, that sounds like more of a pain in the *** then i was hoping it to be
weird thing is, is it only seems to click on when its revved past ~4k
Civ!c*chick
Aug 16, 2011 05:48 PM
west nile
Dec 2, 2009 11:21 AM
PhantomX
May 4, 2009 03:27 PM
HackAbuse
Mar 5, 2007 01:22 PM
