Did i blow my ringlands...again!?
My cars been out of comm. for awhile...Since then I changed the battery, oil, fluids, and ignition coil out of my dizzy... so I start it up and its Miss firing and theirs a lot of vibration... i check the spark plugs and theres oil on all of them...... also theirs smoke coming from Cylinder 2 from the left (when i took out the spark plug)....
Is my motor Done???
Is my motor Done???
Re: Did i blow my ringlands...again!?
do a compression test, better yet a leakdown. you could also open the oil cap and start the engine up. See you have alot of smoke coming out of it then you either blew a ring land or melted a pistone. If you keep on blowing engines up suggest either stop driving like a 16 year old or get a new tuner.
The only other thing that could get oil into your cylinder is if it came from the head or the intake. Check your charge piping and see if your turbo seals are gone. Run a leakdown and then your guessing ends.
jaymes2030
01-19-2004 07:14 PM
