5 lug conversion questions.
Old Jun 27, 2002 | 05:53 PM
racecarpete's Avatar
Default 5 lug conversion questions.
I did a search but didn't really find what i wanted. I drive a 2000 ex and will be purchasing a 5 lug conversion from an ITR. My question is, do i use the stock civic front LCA or the tegs to make the conversion work because i will be purchasing LCA, shock forks, sway bar, etc. from an Si to run the 26mm front sway bar and i hope this is not all a waste. Also i heard that by running the teg knuckles i will have a little bit of positive camber. This isn't anything a camber kit can't fix right? thanks in advance.
Old Jun 27, 2002 | 05:55 PM
Brian*'s Avatar
Default Re: 5 lug conversion questions. (SilverCivic2k)
use the Si LCA's, they will work
Brian
Old Jun 27, 2002 | 05:56 PM
jonas's Avatar
you cant use the ITR LCA's.
camber isn't that bad.. camber kit will do fine.
Default Re: 5 lug conversion questions. (jonas)
cool thanks guys.
Old Jun 27, 2002 | 07:36 PM
sammysnakes's Avatar
Old Jun 27, 2002 | 09:25 PM
Blue-Civic-Hybrid's Avatar
Loved
you can use your stock ones, but no sway bar...
Old Jun 27, 2002 | 09:27 PM
Default Re: 5 lug conversion questions. (Blue-Civic-Hybrid)
why is that? I'm going to be using the SI LCA and sway bars so why wouldn't this work?
Old Jun 27, 2002 | 09:28 PM
fowler!'s Avatar
positive camber or negative camber? I never noticed a difference when I did mine
Old Jun 27, 2002 | 09:29 PM
fowler!'s Avatar
He's talking about using your stock dx/ex LCAs. You won't be able to use the sway bar if you don't upgrade to the SI LCAs...but you will still be able run the 5 lug brakes..
Old Jun 27, 2002 | 09:35 PM
Default Re: 5 lug conversion questions. (fowler)
ok i guess, i mean cause i am running an ex and already have the stock 22mm sway bar just want to upgrade to the beefier 26mm so i didn't understand what he meant maybe he thought i had a dx or something.
Old Jun 27, 2002 | 09:42 PM
fowler!'s Avatar
You still need the Si LCAs to run the 26mm sway bar. You can't use the EX ones.
Old Jun 27, 2002 | 09:44 PM
yeah that's cool i know that, i already am in the process of purchasing the lca, forks, brackets and endlinks to make it work as stated above. thanks anyway.
Old Jun 28, 2002 | 11:59 AM
jonas's Avatar
SLIGHT negative. but i already had some negative camber before i did the 5 lug. so maybe i'm trippen
Old Jun 28, 2002 | 12:47 PM
fowler!'s Avatar
negative I can deal with...positive would not be a good thing.
rockdude14
11
Mar 2, 2006 12:26 PM
ThrashSM
Jul 20, 2004 10:58 AM
EricUSC
Apr 30, 2003 07:44 AM
EricUSC
Apr 26, 2003 05:00 AM
EricUSC
13
Dec 17, 2002 01:35 PM
