Starter Problem...
Old Dec 17, 2007 | 08:43 PM
hndacord02's Avatar
Default Starter Problem...
car:99 civic si W/ B18C... Using B16a2 Trans w/starter.
The bat was dead from sitting for 4 months, so we jumped the car... When I turn the key, I hear a spinning noise, but no cranking of the motor. I just got the motor put back to together, so the timing belt is brand spanking new, flywheel was fine when I put it back in... I am charging the battery overnight, and will see what happens tomorrow... is it possible that jumping it wont make it turn over?
If it still makes the sound, any ideas? new starter maybe? is the b26 starter not powerful enough?
Thank for the input guys!
Old Dec 18, 2007 | 06:54 AM
hndacord02's Avatar
Default Re: Starter Problem... (hndacord02)
anybody?
Old Dec 18, 2007 | 07:01 AM
trickeng's Avatar
sound like the starter solonoid is not engaging the starter gear. give it a little tap with a hammer.
Old Dec 18, 2007 | 09:34 AM
slomofo's Avatar
GDD Member
Change the starter.
Old Dec 18, 2007 | 12:59 PM
Perfectionist's Avatar
There is a 'bendix' on the shaft of the starter motor that should engage the flywheel and crank the engine. That isn't happening by your description, and that's why there is only a spinning noise (the starter motor spinning). The bendix may be gummed up.
Old Dec 18, 2007 | 09:51 PM
hndacord02's Avatar
Default Re: Starter Problem... (Perfectionist)
ok, ill give that a try, it wasnt the batt... we charged it, and it still did the same thing...
dmanfree
Jun 21, 2013 12:38 PM
h22a_black
Feb 13, 2008 06:12 AM
blakacintegra
Nov 7, 2007 01:16 PM
Kimbo
Dec 2, 2005 05:32 PM
speedracer33
11
Jul 11, 2005 08:00 AM
