Quick question on LED Alarm light location
Old Dec 17, 2007 | 01:40 PM
vlc92189's Avatar
Default Quick question on LED Alarm light location
Well this week im getting my clifford alarm installed, and i want a clean look. I was thinking to put the led in the basic place, on top of the steering column but i was thinking, i have a delete where the cruise control is supposed to be, but since i dont have cruise control.. leaves a delete there. the car is a 98 hx. any suggestions or oppinions where your lights are?
and how do you get the delete off? do i gotta tke the whole vent assembly off? if so how?
thanks guys.
Old Dec 17, 2007 | 04:39 PM
fcm's Avatar
fcm
Old Fart
Default Re: Quick question on LED Alarm light location (vlc92189)
The LED should be placed where it is visible from any window in the car and/or the cheapest piece of plastic to replace if system removed, a dummy plug, [delete] would be a good spot as long as it can be seen. 94
Old Dec 18, 2007 | 04:16 AM
White Smoke's Avatar
i my honda
Global Mod
The vent just pops out, from the bottom first I believe.
Old Dec 18, 2007 | 07:21 AM
vlc92189's Avatar
Default Re: Quick question on LED Alarm light location (White Smoke)
i must be a retard but i cant seem to find a way to even pop it out
Old Dec 18, 2007 | 10:08 AM
i my honda
Global Mod
If you removed the driver side lower kick panel you can look up at the vent and see the two little metal prongs that wedge it in there. You should be able to pop it out from the bottom but if not push up on those metal things and it should come right out.
Old Dec 20, 2007 | 12:13 PM
CivicPride97's Avatar
you can also take the whole buttom dash off which is being held in by clips and 3 screws (I dont know if thats what whitesmoke was talking about and if it is sorry ).......then right there you can poke out the delete.......you can also mount the led on the driver side A pillar where it will definitely be noticeable....
mikeycivic
Audio / Security / Video
Dec 5, 2009 01:16 PM
del sol1658
Oct 9, 2008 12:55 PM
93civciv
Jan 22, 2006 02:25 PM
.Ryan
May 17, 2003 09:17 PM
joblow
Nov 18, 2002 09:20 PM
