Dome lights
They work in the "on" position, but not when door opens. I have no power getting there. Also no power to map lights. Check all fuses under knee kick panel and they are fine. Also new door pins. This is n a 2000 civic si
Little help. Thanks
Little help. Thanks
When you switch out your Stock headunit for an aftermarket one, they will stop working. Theres something in the stock unit that controls door lights and lock remote (factory one). PM NOFX, she explains this ordeal better than i can, lol. You can actually do soemthing to make it work again.
If you still have the stock head unit installed, it may be a bad switch in the door jam.
Aftermarket deck, not installed yet, but no stock deck around. Brand new door switches. They used to work fine, when the car had an alarm ( keyless entry worked ) but after the wreck, I took out the old alarm and waiting for new.
ll try PM NOFX, thx Mike
My car did this too and the wiring under the dash was cut by the previous owner. You may want to check their too and I have an aftermarket deck and now it works after finding the wiring problem.
Only wires are cut are a blue and a green coming from the old stock radio harness for a power and a ground that they had the old alarm hooked up to. I can be sure that there no other wires cut, because I had the whole dash and wire harness out of the car.
I can't help you from here then. Good luck! I just dealt with mine for a year an a half and when my friend was putting my alarm in they found it so its nice to have it but you get used to not having it.. It sucks
Mike, NOFX said that it only does it on 96 - 98
superd16girl, yea I wouldnt really mind it, but Im trying to install the column keyhole light, so no power, no testing and no getting to work hehe
Anyone know if there is a relay for it??
Modified by C-West Civic at 3:46 PM 12/17/2007
Chill_World
Honda Civic (2006 - 2015)
Mar 25, 2018 07:08 AM
HONDRETTI
Audio / Security / Video
18
Jun 8, 2009 05:53 AM
