CEL code 9
Old Dec 17, 2007 | 10:07 AM
hatchback freek's Avatar
Default CEL code 9
my car is throwing code 9, i have 96 civic sedan with an obd1 motor and p75 ecu, i wired the distrutor and the car runs great, accept the #9 cel code, does this mean i need a new distrbutor? thanks for the help.
Old Dec 17, 2007 | 10:15 AM
97Ej6mike's Avatar
9 CYP - cylinder sensor
First of all, what exact motor are you running?
Old Dec 17, 2007 | 11:20 AM
Default Re: (97Ej6mike)
jdm b18b
Old Dec 19, 2007 | 07:35 PM
Sl0wEK's Avatar
Default Re: (hatchback freek)
I have the same problem except I have a 97 civic with a USDM LS motor and running an OBD1 PR4 ecu. Can anyone help us?
Old Dec 20, 2007 | 03:54 AM
Default Re: (Sl0wEK)
from all my reserch, i think we might have to get new distributors
Old Dec 20, 2007 | 06:09 PM
Sl0wEK's Avatar
did you try with an obd2 ecu? mine work fine with an obd2 ecu but i wanna jump it back to obd1 so i can put in a turbo kit and get my car tune
Old Dec 23, 2007 | 03:58 PM
no i tried that, i did a whole obd2 to obd1 conversion, the motor is an obd1 motor, i think i just need a new distributor, and a oxygen sensor. thank man.
Old Dec 23, 2007 | 04:00 PM
Luserkid's Avatar
My guess (provided its a good working Dist.) is that you redid the wiring wrong. But yes normally when these codes (CYL, TDC, CKP) come up it means time for a new dist.
Old Dec 23, 2007 | 04:50 PM
iluvmy2000civicex's Avatar
Default Re: CEL code 9 (hatchback freek)
I had to get a new distributor on my 2000 civic and it never gave me any codes. Just stopped running on my way home one day. 300 buks down the drain.
Old Dec 28, 2007 | 05:19 PM
i redid the wiring, and still the code. im getting a rebuilt one from pep boys some time. thanks for the help
https://honda-tech.com/zerothread?id=2161432
Modified by hatchback freek at 6:34 PM 12/28/2007
2Point3
May 20, 2009 05:18 PM
beseman
Aug 24, 2006 10:18 AM
b20izzle
Oct 26, 2005 07:52 PM
Boost2NA
Aug 29, 2004 08:15 PM
AzNpRiD3
May 14, 2004 06:05 PM
