built and bossted b16. have some questions
Old Dec 16, 2007 | 07:49 PM
2000siturboR's Avatar
Default built and bossted b16. have some questions
hes the line about 3 months ago blew my motor due boost and beating it. now after i had some money saved up decided to build for boost. got lower copression pistons and some eagle rods. im only running at 7 psi. my question is due to lower compression pistons is it nessacary for a tune or not running hondata s200. anything i need to do befroe driving the car again
Old Dec 16, 2007 | 08:18 PM
ke98248's Avatar
Default Re: built and bossted b16. have some questions (2000siturboR)
You MUST get your car tuned no matter what..
Make sure you have:
walbro 255 fuel pump
larger injectors
good intercooler/radiator/fan
Old Dec 16, 2007 | 09:10 PM
gt35r's Avatar
Default Re: built and bossted b16. have some questions (ke98248)
what he said. Depending on your setup..everything varies. but forsure TUNE. even with low compression you will hurt your motor if you dont tune. You can find a local tuner who can chip a ecu p28, po6 p05 something like that and tune with crome for you.
Old Dec 16, 2007 | 09:45 PM
Default Re: built and bossted b16. have some questions (gt35r)
no kidding i need it tuned with a turbo i aint stupid it was tuned and everything before i rebuilt it. the only thing different now it lower compression pistons. and yea i have all the injectors and fuel pump. i have the 99-00 turbo setup from greddy
Old Dec 17, 2007 | 01:58 PM
.PLUMMM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000siturboR &raquo;</TD></TR><TR><TD CLASS="quote">hes the line about 3 months ago blew my motor due boost and beating it. now after i had some money saved up decided to build for boost. got lower copression pistons and some eagle rods. im only running at 7 psi. my question is due to lower compression pistons is it nessacary for a tune or not running hondata s200. anything i need to do befroe driving the car again</TD></TR></TABLE>
Woah buddy, no need for an attitude! If you knew you had to get it tuned then what is the point of this thread big guy?
cityofcaterpillars
Engine Management and Tuning
Feb 13, 2017 04:02 PM
94hatchvx
Nov 5, 2006 09:34 PM
BOOSTED-EG
Jun 17, 2004 05:33 PM
01ITR#700
Jun 2, 2003 07:31 AM
swpdb16
Oct 30, 2002 09:48 PM
