Battery disconnect switch
Old Dec 16, 2007 | 08:52 AM
B16A1-EF9's Avatar
Default Battery disconnect switch
I know this has probably been covered before but I've searched and wasn't able to find what I was looking for.
I've always heard that improper hook-up could cause the alternator to keep everything alive when the motor is running after switching it off. I've made a diagram of the way I think it should be hooked up. Can you guys take a look over it and let me know what you think. It's for my race car....thanks in advance.
Old Dec 16, 2007 | 11:06 AM
Garage 808 Hatch's Avatar
Default Re: Battery disconnect switch (B16A1-EF9)
looks good to me.
Old Dec 16, 2007 | 11:10 AM
B16A1-EF9's Avatar
so the way i have it wired it should turn the car off and the alternator wont keep it running right?
Old Dec 17, 2007 | 07:47 AM
boosted_dc2's Avatar
Default Re: (B16A1-EF9)
yes it will turn the car off when you turn the switch off if you wire it like that.
Landon
Old Dec 17, 2007 | 08:10 AM
adrian1281's Avatar
follow this link:
http://moroso.com/catalog/cate...42225
and read the instructions for item #74102, it should help...
Old Dec 17, 2007 | 02:22 PM
B16A1-EF9's Avatar
what worries me about their diagram is that it says 20 amps max for the alternator, i'm sure i would use more then that???
any ideas?
Old Dec 18, 2007 | 07:42 PM
adrian1281's Avatar
i think the 20 amp rating is dependent on the gauge of the wire they are specifying, in this case 10 gauge. if you're worried about it use something bigger like maybe 8 gauge. i'm almost positive the switch itself can handle more.
84Riceeater
Feb 17, 2015 02:25 PM
ZCHondaCRX91
Oct 5, 2011 03:19 PM
philosofy1
11
Dec 8, 2007 09:33 PM
flip1199
Jun 19, 2004 12:13 PM
