Lighting HID/Xenon kits, Retrofits and Associated Topics
To those with LED dash lights...
Old Dec 16, 2007 | 06:25 AM
egvtec's Avatar
Default To those with LED dash lights...
Do they dim with the oem dimmer once you replace the factory bulbs with leds?
Im sorry if this has been covered i did a quick search with no luck.
Old Dec 16, 2007 | 11:58 AM
CarbonizedDX's Avatar
Default Re: To those with LED dash lights... (egvtec)
if you are using led bulbs in the factory bulb holders yes, if you have done led flex strips of installed led's on a board it'll depend if you wired them to the factory light wiring. I've got led flex strips in my gauge cluster and my hvac and I wired both to the factory illumination wires so they dim off the dimmer as they should.
Old Dec 16, 2007 | 05:17 PM
Genuine Rolla's Avatar
Mine did not dim at all.
Old Dec 16, 2007 | 10:39 PM
Default Re: (Genuine Rolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Genuine Rolla &raquo;</TD></TR><TR><TD CLASS="quote">Mine did not dim at all. </TD></TR></TABLE>
How do you have them connected?
Old Dec 17, 2007 | 09:01 AM
k0rupt_ed's Avatar
are there any hotspots with the #74 replacement led's?
Old Dec 26, 2007 | 07:32 PM
egvtec's Avatar
good question do the 194 bulbs have a hot spot if they are LED replacements?
Old Dec 26, 2007 | 08:25 PM
74's will have hot spots unless you sand the led to diffuse the light but their problem is they lack sidelight which the cluster is designed around.
194's can have hot spots, I honestly can't remember with mine but again if the led is sanded down it'll diffuse the light and as long as multi led units are used they'll fill the cluster with light better than just single forward firing led's.
Autolumination sells a tri-led 74 bulb, I've not used it but I read somebody else say it had less hot spots but I can't say for sure:
Super bright leds sells a "high powered SMT" led 74 bulb, I've not used it so I couldn't say how well it works but with the lower profile design it should illuminate better and have a lower chance of hot spot...
Another option would be to modify the #24 tri-led unit to fit into the 74's base, it'd provide more light but also require the installation of the bulb from the front of the cluster into the bulb holder than from the back as normal:
I've used the 194 version of this bulb (has 4 chips) and it's bright and the light is wide and even...
Old Dec 27, 2007 | 08:39 AM
Default Re: (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">
How do you have them connected?</TD></TR></TABLE>
I have the tri-led's in 74's in the OEM locations.
Mr. Prelude
May 12, 2011 03:16 PM
LS stretch
Lighting
Apr 20, 2010 12:32 PM
Red_ED8
Sep 15, 2007 11:11 AM
claytonsmith
Mar 1, 2007 10:10 PM
Kyles ej1
Feb 11, 2005 05:27 PM
