CTR cams question
Old Jun 27, 2002 | 11:38 AM
JoeSiR's Avatar
Default CTR cams question
I'm about to install my CTR cams with valvesprings in my B16A,but I'm running on the stock ECU P30 (8200RPM cutoff),do I have to chip my ECU to get the full potential of these cams?Cause I know CTR can rev to 8500RPM without problems!
Thanks
Old Jun 27, 2002 | 11:40 AM
Spade's Avatar
Default Re: CTR cams question (JoeSiR)
To get the FULL potential yes. But in the meantime, have fun!!!!
Old Jun 27, 2002 | 11:52 AM
moyerek's Avatar
get a chip.... i don't know how good they are but I saw some generic chips go as low as $50 bucks on eBay
Old Jun 27, 2002 | 11:56 AM
JoeSiR's Avatar
Default Re: CTR cams question (moyerek)
I know one guy who could chip my ECU with a mugen chip for 125$.
Old Jun 27, 2002 | 12:00 PM
Spade's Avatar
You can do it but, if you don't have your engine done, I would wait.
Old Jun 27, 2002 | 01:08 PM
erniecars's Avatar
Default Re: CTR cams question (Spade)
I put ctr cams in my b16. I had to chip the ecu because vtec was at 4800 which is way too low for those cams. I got a "generic" chip which is actually a copy of a spoon chip that put vtec at 5500 and redline at 8700 so no more bogging when vtec kicks. The chip was $20 on ebay. Very easy to install.
Old Jun 27, 2002 | 01:24 PM
LB CRX's Avatar
dont waste 125....too much. i know a guy that does it for 80. you need your reev limiter to about 8500 to 9000, it really depends on your setup. My setup (seen below) required my to go to 9k to get full potential. good luck
Old Jun 27, 2002 | 03:40 PM
Urban Business
Guest
Posts: n/a
Default Re: CTR cams question (LB CRX)
so your reving to 9k on a stock valve train...
Old Jun 27, 2002 | 05:53 PM
bryant's Avatar
Default Re: CTR cams question (TorteX)
I agree, upgrade your valve train first before you get that chip. You dont want valve float.
Old Jun 27, 2002 | 06:08 PM
LB CRX's Avatar
i thought he said that hes getting the CTR valve springs?
Old Jun 27, 2002 | 06:40 PM
JoeSiR's Avatar
Yeah that's right i'm getting ITR valvesprings with CTR cams.
So,8200 RPM is it OK for CTR or I have to rev to 8600 or more to get the full potential of CTR cams???
Old Jun 27, 2002 | 07:44 PM
bryant's Avatar
Oh sorry, i guess i need to fully read before i post up pointless info like that again. But reving to 8.2K is fine, but if you have all the other stuff in there and that chip with more fuel, 8.6K is fine for the CTR cams. I think I remember seeing a dyno and the cams power dyes off around 8.5 or 8.6K RPM.
1New_Life6
Feb 10, 2012 11:02 AM
asocallocal
Nov 26, 2004 11:06 AM
Option
May 18, 2004 10:17 PM
99 TYPE R
Mar 2, 2004 08:23 AM
rbf351
Dec 26, 2002 06:43 AM
