HELP WITH LEAKING OIL FROM ENGINE!!!!
Old Dec 13, 2007 | 05:18 PM
lilskud13's Avatar
Default HELP WITH LEAKING OIL FROM ENGINE!!!!
Alright, I have a slight oil leak where my head and block meet. the head has been replaced before I got the car. i was thinking about getting the block resurfaced, but let me know what to do.Thanks
Old Dec 13, 2007 | 05:46 PM
z6hatchboy's Avatar
you could try taking the v/c off aand see if the head bolts are torqued to spec. If they're good then it might be time to look at the head gasket and if its good, try resurfacing, thats my $.02
Old Dec 13, 2007 | 06:13 PM
lilskud13's Avatar
Default Re: (z6hatchboy)
Thanks man. Im going to get on that tomorrow. Ill post more asap
Old Dec 13, 2007 | 08:16 PM
IMALLSLO's Avatar
Is the leak on the trans side? Puddles up in a little spot on the block? The leak is external IE. valve cover gasket,distributor O-ring and depending on if its twin cam,it could be a cam plug or Vtec seal. Check all those and let us know. Dont worry about a headgasket,its not that. People think oil will actually leak out of the head and onto the left corner of the block and puddle up LOL!
Old Dec 13, 2007 | 08:23 PM
ferio252's Avatar
Default Re: (IMALLSLO)
I had a similar problem and it turned out to be my valve cover gasket not being sealed correctyl. I don't know if this will apply to you.
Old Dec 13, 2007 | 09:19 PM
DLjunky's Avatar
Default Re: HELP WITH LEAKING OIL FROM ENGINE!!!! (lilskud13)
I have the same problem, but I think it might be my cam seal or my Valve Cover gasket. I have both parts just waiting for a sunny day to do work on it.
Old Dec 13, 2007 | 09:34 PM
SOHCejcivic's Avatar
Default Re: HELP WITH LEAKING OIL FROM ENGINE!!!! (DLjunky)
any time i've ever mismatched a head and it's original block, i've ALWAYS had an oil leak there....just food for thought. oil never made it into the coolant, and compression was perfect....i just had that leak.
Old Dec 13, 2007 | 09:38 PM
93egSLEEPER's Avatar
Default Re: HELP WITH LEAKING OIL FROM ENGINE!!!! (SOHCejcivic)
might be a cam seal leaking... did u use silicone when you put it on?
Old Dec 14, 2007 | 09:48 AM
lilskud13's Avatar
HMMM..the oil leak is on the trans side. I know this is very common. I didnt put the head on, I bought the car as it is. Ill take a look at the valve cover gasket and other things and see if i can figure it out..thanks again
Old Dec 18, 2007 | 07:56 PM
redDAinteg's Avatar
subscribed
Old Dec 18, 2007 | 08:09 PM
egsleepercivic's Avatar
replace your dizzy o-ring, thats what fixed it for me
gl
Old Dec 18, 2007 | 08:15 PM
jime64871's Avatar
Default Re: (egsleepercivic)
take the head completely off the block. remove gasket. place a thin layer of honda-bond around all the oil guides and head studs. Also apply on the head. lay head gasket on block with head studs in place. Drop down head and torque to spec.
had the same problem, honda-bond fixed!
pooRmansss
Feb 19, 2009 03:24 PM
ALL MOTOR DA
11
May 1, 2006 02:48 PM
TallAssFilipino
12
Sep 19, 2004 06:23 PM
Nextelbuddy
May 5, 2003 08:10 PM
12secB18acivic
Nov 24, 2002 10:58 PM
