rear disc conversion?
Old Dec 13, 2007 | 01:59 AM
v8destroyer's Avatar
Default rear disc conversion?
i have a 95 civic ex and im wanting rear disc brakes... where can i find this conversion??? junkyard? if i do get it from a junkyard what parts will i need and off what year and model?? any help is appreciated. thanks
Old Dec 13, 2007 | 04:18 AM
B16B_coupe's Avatar
HRD PKR
Default Re: rear disc conversion? (v8destroyer)
you can get rear disc off of any civic,teg with rear disc...
i believe integra e-brake cables work on 92-95 civic as well as 92-95 si e-brake cables ...
you use your lower and upper rear control arms and alignment arms... but some are interchangeable, depending on which rear disc you get
Old Dec 13, 2007 | 04:41 AM
what about wheel hubs?
Old Dec 13, 2007 | 09:22 AM
BlueIntegraBoy's Avatar
This is what you need to pull off
Old Dec 13, 2007 | 10:58 AM
EL Vap133's Avatar
Default Re: rear disc conversion? (BlueIntegraBoy)
Wow, that looks like my pic!
Old Dec 13, 2007 | 11:03 AM
97Ej6mike's Avatar
Default Re: rear disc conversion? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, that looks like my pic! </TD></TR></TABLE>
copyright infringment!
Old Dec 13, 2007 | 11:06 AM
PrimeElement's Avatar
Default Re: rear disc conversion? (97Ej6mike)
I recently did this conversion on my car. I picked up the rear disk as shown in that pic above off a DC2 in a junkyard for $200, calipers were still fresh, didnt even have rust. The ebrake cables from my civic didnt work anymore, had to get a set for an integra. The brake lines will most likely be cut on them cuz ppl are lazy when removing the trailing arms. If you find them uncut, you're in luck but otherwise you will most likely have to pick those up too. I had aftermarket skunk2 rear control arms so I have no idea if the factory ones will bolt up nice.
Modified by PrimeElement at 3:27 PM 12/13/2007
Modified by PrimeElement at 3:28 PM 12/13/2007
Old Dec 13, 2007 | 11:25 AM
EL Vap133's Avatar
Default Re: rear disc conversion? (PrimeElement)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrimeElement &raquo;</TD></TR><TR><TD CLASS="quote">I recently did this conversion on my car. I picked up the rear disk as shown in that pic above off a DC2 in a junkyard for $200, calipers were still fresh, didnt even have rust. The ebrake cables from my civic didnt work anymore, had to get a set for an integra. The brake lines will most likely be cut on them cuz ppl are lazy when removing them. If you find them uncut, you're in luck but otherwise you will most likely have to pick those up too. I had aftermarkey skunk2 rear control arms so I have no idea if the factory ones will bolt up nice.</TD></TR></TABLE>
Yes, you can use 94-00 Integra rear LCAs on a 92-95 Civic with no problem.
Old Dec 13, 2007 | 11:28 AM
fmrprojects's Avatar
find some on here they go for cheap. i've sold like 3 sets for under 200 including the brake lines
Old Dec 13, 2007 | 04:37 PM
LOL, I searched the marketplace for pics and I guess your pic looked the nicest.
Old Dec 13, 2007 | 08:36 PM
thanks for the help everyone!
Old Dec 13, 2007 | 09:13 PM
my friend litterally just now wrecked his crx, he got t boned and he said hes pretty sure its totaled.. can i use his rear discs? its a 90 crx si
Old Dec 13, 2007 | 09:44 PM
SOHCejcivic's Avatar
Default Re: (v8destroyer)
i don't think so...i could be wrong. if i'm not mistaken, you need them off either a 92-95 civic si, civic ex sedan with abs, any dc integra or a del sol si.
Old Dec 14, 2007 | 03:06 AM
Default Re: (SOHCejcivic)
^This man is correct.
Old Dec 14, 2007 | 06:22 AM
2tonecivic21's Avatar
Default Re: (PrimeElement)
If your willing to spend the money, I would suggest an aftermarket drum to disc conversion and then an upgraded front disc kit. Fastbrake makes a kit for both but it is a lot more expensive than a junkyard swap.
Old Dec 18, 2007 | 07:54 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">i don't think so...i could be wrong. if i'm not mistaken, you need them off either a 92-95 civic si, civic ex sedan with abs, any dc integra or a del sol si.</TD></TR></TABLE>
Actually they will fit, pretty much all rear disc brakes from 90-00 are the same for Civics/Integras/CRX's.
Old Dec 24, 2007 | 03:22 PM
scuzz's Avatar
Default Re: (EL Vap133)
Something I'm still confused about is, will 90-93 Integra rear disk stuff interchange with the 92-95 hatchback?
I've read that they do and elsewhere that they don't.
Old Dec 24, 2007 | 03:31 PM
CapnKrunch's Avatar
Default Re: (scuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuzz &raquo;</TD></TR><TR><TD CLASS="quote">Something I'm still confused about is, will 90-93 Integra rear disk stuff interchange with the 92-95 hatchback?
Yes, the DA disc brake trailing arms are interchangeable with EG's, but the DA ebrake cables won't work, you'll need to source some from a DC 2/4 door, or a 92-95 EX/Si civic w/ rear discs.
delsolo95
May 19, 2012 11:12 AM
ek4ferrio
Oct 9, 2006 07:01 PM
Soichiro-son
16
Mar 29, 2006 09:03 AM
skunkcoupe
12
Nov 12, 2004 11:59 AM
eghatchproject
Mar 16, 2004 07:05 AM
