pr3 ecu in a d16a
just put in a pr3-j01 ecu in my del sol which normally runs a p28... this ecu threw a code but runs fine and vtec kicks in at 5700 rpms. Im buying a vtec controller so it kicks in at around 5 for more usable powerband. any one have any information about this or what i should set my vtec at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick »</TD></TR><TR><TD CLASS="quote">sTeena]its a jdm d16a6 from a fiero i believe, i never swapped my head but i know it's SOHC vtec.</TD></TR></TABLE>
ferio never came with a d16a6
there is no jdm d16a6 the 6 denotes that
a d16a6 is not an sohc vtec
a d16a6 is from an 88-91 CRX si or civic SI
you probably are thing d16z6, in that case the PR3 is for a b16a motor, better off selling it and buying a p28 to get it to run right, they cost about the same, other wise you can chip it and load it with a p28 BIN/ROM which i can email to you.
you need a chip burner, soldering skills, and the faq from pgmfi.org click on how to chip my ECU
ok then its a d16a_ what? i know its a d16a and i ordered it from japan, i know it's SOHC and i know it has vtec, i can show you pictures of my vtec solenoid...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick »</TD></TR><TR><TD CLASS="quote">sTeena]ok then its a d16a_ what? i know its a d16a and i ordered it from japan, i know it's SOHC and i know it has vtec, i can show you pictures of my vtec solenoid...</TD></TR></TABLE>
if it is truly a JDM d16a then its called that d16a. pretty rare engine thats probably why you couldnt find info on it.
still the PR3 is not the proper ecu for it. a p28 will be the best soulution for that particular motor.
yes a JDM d16a is sohc vtec........you stated numerous times its a d16a6 which is NOT the same engine. be careful before you type motors...........................the NUMBEr does matter
d16a1 - dohc non vtec first gen integra
d16a6- sohc 88-91 crx si
d16a- JDM sohc vtec
see how there is a diffrence?
but what you can do is go ahead and show the motor stamp, ill tell you exactly what motor it is.
d16a- JDM sohc vtec
thanks that clears a lot of things up... ill take pictures in a bit... so my engine number is d16a no other numbers right? thats weird...
haha i've got 2 sitting in my car, but vtec hits harder and my car seems faster in general with a pr3 ecu, i have no idea why, but ill set that one for 4800 and send it in to get it chipped... i wonder if the fuel maps are different or something like that...
ProjectCRXtacy
May 3, 2002 01:17 AM
