DA integra fuel problem. Code 43
So i just checked my ECU and it was throwing Code 43. Fuel Supply System.
My car dies out on me like its not being fed gas at certain times. Any one know what i can do to overcome this nightmare ive been having with this problem?
I am also haven a fuel problem...I think anyways...Car just wont start, but trys and all I can think of is the fuel pump...You have a DA, so I didn't know if you would have a idea of how I would know if I have a bad fuel pump or not...
New Fuel pump is like $130 and I have to drop the tank
so I dont just want to go fixing something that might not be broke...
Anyhelp would be great, or even what you think...
so I dont just want to go fixing something that might not be broke...Anyhelp would be great, or even what you think...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITRTURBO »</TD></TR><TR><TD CLASS="quote">I am also haven a fuel problem...I think anyways...Car just wont start, but trys and all I can think of is the fuel pump...You have a DA, so I didn't know if you would have a idea of how I would know if I have a bad fuel pump or not...
if you have a honda/acura you don't need to drop the tank to get to the fuel pump. just remove the rear bottom seat cushion.
</TD></TR></TABLE>if you have a honda/acura you don't need to drop the tank to get to the fuel pump. just remove the rear bottom seat cushion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">
if you have a honda/acura you don't need to drop the tank to get to the fuel pump. just remove the rear bottom seat cushion.</TD></TR></TABLE>
I believe with OBD0 Integras you do have to drop the tank to get to the fuel pump.
Hmmm, I have replaced my fuel filter, o2 sensor, and 2 different used regulators (cousin works at a honda junkyard so I get them for free :D). Im still jumping between 300 and 1500 RPM randomly, it will be like 800rpm for 30 sec, then 500rpm for 3sec, then 1200rpm.... and it spits out code 43 when I sit and let it warm up. BTW, I drive a 90 hatch with B18 swap, and matching integra ECU.
