CEL with 2000 gsr testpipe
Old Jun 26, 2002 | 06:55 PM
PurpleGsR00's Avatar
Default CEL with 2000 gsr testpipe
i obviously got a CEL with my testpipe.. is it ok to drive with it on?
Old Jun 26, 2002 | 07:07 PM
builthatch's Avatar
MiG-21 superfan
Default Re: CEL with 2000 gsr testpipe (PurpleGsR00)
i think that it mite negate any gains youll get from the testpipe by changing its fueling and timing values due to the cel.
Old Jun 26, 2002 | 08:00 PM
Default Re: CEL with 2000 gsr testpipe (builthatch)
ohh so the CEL does make the car slightly slower correct??
are there any cheap alternatives to preventing the CEL from comming on
and by the way im coverting my car to obd1 soon.. so im sure that will permanantly fix the problem
Old Jun 26, 2002 | 08:05 PM
Spade's Avatar
WHen you vehicle throws a cell, it goes into "limp mode" and VTEC will not engage.
Take your secondary O2 and wrap it in aluminum foil. then tuck it away somewhere where it won't get damaged. Then clear your ECU and your done.
BTW, you can get a $3,000 fine for having a test pipe.
Old Jun 27, 2002 | 01:56 AM
kinesistech's Avatar
This is how to fix your light and keep your pipe. The secondary o2 sensor is there only to check catalytic convert efficiency. If you zip tie it and let it breath free air, which is about 21% o2, it will not throw a code because it sees clean air.
Old Jun 27, 2002 | 05:59 AM
b18b98's Avatar
i thought any codes being thrown from the secondary 02 doesn't put the car into limp mode and only the primary 02 does?
Old Jun 27, 2002 | 06:14 AM
TGUNNER's Avatar
Default Re: CEL with 2000 gsr testpipe (b18b98)
correct!!! the secondary o2 sensor does not put the car into limp mode.. its only there to show condition of the cat!!!!
Old Jun 27, 2002 | 06:29 AM
Spade's Avatar
Default Re: CEL with 2000 gsr testpipe (TGUNNER)
Lesson learned.
Old Jun 27, 2002 | 06:36 AM
brcivic411's Avatar
so, if you don't mind driving with a CEL, you'll be cool.
the only problem is that you might not be aware of any other CELs
Old Jun 27, 2002 | 07:55 PM
Default Re: CEL with 2000 gsr testpipe (brcivic411)
i thought something was kinda fishy.. cuz my VTEC was sure comming on!!!!!
LOL.. i guess im gonna deal with the yellow annoying light.. thanks PPL!
Old Jun 27, 2002 | 08:27 PM
cj7420's Avatar
New User
can I cut the damn wire to my CEL I hate that thing?
Ghetto Civic HX
Dec 19, 2007 10:17 AM
ActiveAero
Jun 16, 2002 06:24 PM
comptechgsr2000
Apr 26, 2002 09:02 AM
Qwikrex
Apr 12, 2002 03:11 PM
Qwikrex
Apr 11, 2002 05:17 PM
