Suspension & Brakes Theory, alignment, spring rates....
Bad Roads, Stiffer or Softer Springs?
Old Dec 9, 2007 | 05:34 PM
b16a4's Avatar
Default Bad Roads, Stiffer or Softer Springs?
Were i live we have very bad roads. just like in austrilia.
Do i need stiffer or softer Springs?
This is for a 99-00 SiR 4 Door Civic
Old Dec 9, 2007 | 08:03 PM
EK_B's Avatar
Softer. Stiffer=more uncomfortable.
Old Dec 9, 2007 | 08:04 PM
slammed_93_hatch's Avatar
Default Re: Bad Roads, Stiffer or Softer Springs? (b16a4)
depends on what you want.
Are you looking for comfort or performance?
Old Dec 10, 2007 | 03:50 AM
b16a4's Avatar
Default Re: Bad Roads, Stiffer or Softer Springs? (slammed_93_hatch)
performance
the highway has lots of bumps and ****.
Old Dec 10, 2007 | 04:14 AM
B16B_coupe's Avatar
HRD PKR
to stiff may be dangerous... it could cause your *** end to bounce and kick sideways... i wouldn't recommend any full coilovers.... maybe some soft spring/strut combo
Old Dec 10, 2007 | 05:33 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Bad Roads, Stiffer or Softer Springs? (B16B_coupe)
adj dampening would be great also.
Old Dec 10, 2007 | 07:57 AM
baller status's Avatar
"Softer" will grip better on bad roads than "stiffer"; although without any frame of reference, those terms are meaningless.
Old Dec 10, 2007 | 08:27 AM
Targa250R's Avatar
be professional
I would suggest just leaving the stock suspension alone.
Old Dec 10, 2007 | 10:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If the car is lowered significantly, softer springs may cause the suspension to bottom out more, which in itself would also make the car ride pretty bad.
Old Dec 10, 2007 | 08:43 PM
b16a4's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">If the car is lowered significantly, softer springs may cause the suspension to bottom out more, which in itself would also make the car ride pretty bad.</TD></TR></TABLE>
what would you suggest
Old Dec 10, 2007 | 09:09 PM
bpr0422's Avatar
Yay we know the car! half of these post dont tell us what the car is...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">This is for a 99-00 SiR 4 Door Civic</TD></TR></TABLE>
What is your goal of this car? auto-x, weekend track monster, daily? etc?
What is your current setup like?
What is your ride height?
What tire size are you running?
Without this how can we help?
Old Dec 11, 2007 | 04:26 AM
b16a4's Avatar
Default Re: Bad Roads, Stiffer or Softer Springs? (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">Yay we know the car! half of these post dont tell us what the car is...
Without this how can we help?</TD></TR></TABLE>
15" rims, 195 55 15
i have on drop springs, dont know the brand
street/ occasional hard cornering.
Old Dec 11, 2007 | 05:01 AM
B16B_coupe's Avatar
HRD PKR
so its a daily car on poor roads... so get like a 1.25 front and 1.70 rear drop and some new struts... and you should be good to go
Old Dec 11, 2007 | 08:11 AM
b16a4's Avatar
what kind of rates
what brand springs
Old Dec 11, 2007 | 10:01 AM
bpr0422's Avatar
any lowering spring kit from eibach, h&r, tien, would do fine.
they make different lowering springs and are marketed at different buyers...
for dampers, go with koni or tokico
Old Dec 11, 2007 | 01:07 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">to stiff may be dangerous... it could cause your *** end to bounce and kick sideways... i wouldn't recommend any full coilovers.... maybe some soft spring/strut combo</TD></TR></TABLE>
Old Dec 16, 2007 | 05:53 PM
.PLUMMM's Avatar
If its a daily, then i'd go softer. Espically if the roads are already harsh...
Old Dec 18, 2007 | 08:37 PM
Targa250R's Avatar
be professional
Default Re: (.PLUMMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .PLUMMM &raquo;</TD></TR><TR><TD CLASS="quote">If its a daily, then i'd go softer. Espically if the roads are already harsh...</TD></TR></TABLE>
It's all relative to what is on the car currently.
I would never go with rates softer than the stock springs. Ever.
If stock springs are too harsh, then sell your car and go buy a Buick.
Old Dec 21, 2007 | 06:44 PM
riceforlife's Avatar
Default Re: (Targa250R)
You could try Konis and GCs and if your looking to slam your ride.... get a higher rate in the front like 400-450 and something softer for the back since your roads apparently suck ***. like 300r
Old Dec 21, 2007 | 08:21 PM
b16a4's Avatar
Default Re: (riceforlife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceforlife &raquo;</TD></TR><TR><TD CLASS="quote">You could try Konis and GCs and if your looking to slam your ride.... get a higher rate in the front like 400-450 and something softer for the back since your roads apparently suck ***. like 300r</TD></TR></TABLE>
thank you
thats the answer im looking for
Old Dec 21, 2007 | 09:40 PM
Default Re: (b16a4)
Np if you have anymore questions im glad to answer what I can.
Old Dec 23, 2007 | 03:22 PM
iluvmy2000civicex's Avatar
New struts if needed and Eibach or Tein springs(soft) and you;ll be fine.
Old Dec 26, 2007 | 08:16 PM
RichieHemingway's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">performance
the highway has lots of bumps and ****.</TD></TR></TABLE>
Contradict much?
power11
Suspension & Brakes
17
Jun 11, 2007 02:25 PM
lumpbuzcut
Suspension & Brakes
Feb 27, 2005 10:46 AM
Weapon_R
31
Feb 19, 2005 02:27 PM
Rising sun #1
Jun 6, 2003 01:37 PM
albert butterbikini
Nov 12, 2001 06:10 PM
