Vtech problems
Old Dec 9, 2007 | 05:10 PM
SHOTMASTERJ 1's Avatar
Default Vtech problems
So i just got my vtec hooked up on my d16z6. My engine check light finally came of but now it comes on if I get up to 4500 rpmwhen the vtec kicks in. What can cause this? Thnx
Old Dec 9, 2007 | 05:31 PM
h22ek9forme's Avatar
Default Re: Vtech problems (SHOTMASTERJ 1)
HOLY **** ITS VTEC
not VTECH
damn
and check you solenoid, oil pres switch
Old Dec 9, 2007 | 05:39 PM
egsleepercivic's Avatar
check the code and this will give you a place to start looking
Old Dec 9, 2007 | 05:54 PM
NOFX's Avatar
H-T White Ops
Default Re: Vtech problems (h22ek9forme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22ek9forme &raquo;</TD></TR><TR><TD CLASS="quote">HOLY **** ITS VTEC
not VTECH
damn
and check you solenoid, oil pres switch</TD></TR></TABLE>
Chill. You're going to see VTEC spelled lots of ways here. If you already can't stand it, this might not be the place for you.
And yes, always check the code if you can. OBDI is usually not as easy to get checked / costs money instead of free at Autozone.
Old Dec 9, 2007 | 06:11 PM
Default Re: Vtech problems (NOFX)
it just kills me, bc it is something so obvious, and the famous thing for honda's,
and I assume he's been in the engine bay and can read the valve cover.
not eaven to mention that he must not know what v.t.e.c. stands for.
but yea
Old Dec 9, 2007 | 06:17 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22ek9forme &raquo;</TD></TR><TR><TD CLASS="quote">it just kills me, bc it is something so obvious, and the famous thing for honda's,
but yea</TD></TR></TABLE>
Do you know what it stands for? Because what it stands for leads one to believe it should be called VVTLEC.
Also, since you're so up on spelling, you might want to check what 's means, especially when applied to the cars you enjoy so much.
Old Dec 9, 2007 | 06:30 PM
Mr H22 if you'r so into to grammar, why don't you read your little comment and see sum of the mistake's u made and then hit me up for spelling. K
Old Dec 9, 2007 | 06:32 PM
Padawan's Avatar
Darth ModerVader
How about everyone tries to lighten up a bit?
Old Dec 9, 2007 | 06:37 PM
spoon93's Avatar
i think this fool just goes on this site to critsize people about there spelling what a joke if you know the answer to his question then answer it if not move on homie
Old Dec 9, 2007 | 06:53 PM
Default Re: Vtech problems (spoon93)
no, I actually get on here for technical help with my car and other things,
I am just tired of reading "I cant figure out why vtec won't work on my stock d16"
I am not talking about basic grammer and that type of ****,
I am saying you thought vtec was spelt with a H,
if its a typo then thats fine.
spelling words is one thing,
mis spelling the initials of something that is quite obvious is another.
look about 10 threads up, you will see another person spelling it vtecH
and I did give you a tip,
check the solenoid and the pressure switch
Old Dec 9, 2007 | 07:02 PM
NOFX's Avatar
H-T White Ops
Honestly, who cares if he misspelled it? We all knew what he meant. Someone probably told him to spell it this way in the beginning.
No need to insult him over it though.
Just let it go and let's let the thread go on with suggestions.
This is just another thread that proves why I wish this site would automatically change "VTECH" to "VTEC" just like it changes "****" to "expletive".
An my header spelt? Any wayz bro, be easy.
Old Dec 9, 2007 | 07:06 PM
"» Search Results
Your search for vtec not engaging returned 997 results."
this should help
https://honda-tech.com/zerothread?id=830163
Old Dec 9, 2007 | 07:49 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
And yes, always check the code if you can. OBDI is usually not as easy to get checked / costs money instead of free at Autozone.</TD></TR></TABLE>
why would you pay somebody to retrieve DTC's on an OBD1 honda when anybody with a paperclip can do it??? thats rediculous
OP: pull the code yourself, report back with trouble code.
Old Dec 9, 2007 | 07:52 PM
NOFX's Avatar
H-T White Ops
Default Re: Vtech problems (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">why would you pay somebody to retrieve DTC's on an OBD1 honda when anybody with a paperclip can do it??? thats rediculous
OP: pull the code yourself, report back with trouble code.</TD></TR></TABLE>
I replied with what most normal people would do because poking their car with a paper clip scares them. I work in auto parts all day, so it's just the answer I'm used to giving.
Old Dec 9, 2007 | 07:55 PM
schardbody's Avatar
I replied with what most normal people would do because poking their car with a paper clip scares them. I work in auto parts all day, so it's just the answer I'm used to giving.</TD></TR></TABLE>
good point
Old Dec 10, 2007 | 02:01 PM
Default Re: (egsleepercivic)
So the code ended up to be 21. So I got some obd1 codes off a site"21 92-95 Civic
93-95 Prelude
94+ Integra VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve". Is this correct info?
Old Dec 13, 2007 | 03:32 PM
schardbody's Avatar
that is correct. you have a bad vtec solenoid, wiring, or ECU.
Old Dec 14, 2007 | 09:02 PM
.PLUMMM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHOTMASTERJ 1 &raquo;</TD></TR><TR><TD CLASS="quote">Mr H22 if you'r so into to grammar, why don't you read your little comment and see sum of the mistake's u made and then hit me up for spelling. K</TD></TR></TABLE>
Haha and since you're on everyone else's case, try spelling you're right next time champ
EGThang
18
Jun 6, 2008 03:26 PM
zcarkid
11
Dec 25, 2007 09:45 PM
mtg4gen
Apr 9, 2007 09:02 PM
antney
Nov 10, 2005 04:36 AM
veilsides2000
Nov 27, 2004 11:18 PM
