Overheating EF hatch
Im not sure why this car is still overheating. I replaced the water pump, I replaced the thermostat, I bleed the coolant multiple times and it seems like theres a never ending supply of air in the coolant. It never overheats just sitting idleing but when you go to drive it, then it over heats. I have my fan hardwired to come on when the ignition is switched on. The car is perfectly in time.
Im in time, I have a new water pump, thermostat, the fan works and the coolant has been bleed. Theres also no water on the dip stick and the car isn't leaking any water anywhere. Any ideas?
You are most likely dealing with a headgasket. As soon as you get driving you build enough pressure for the gasket to open up and cause the overheat condition. There are a few companies that sell kits to check for hydrocarbons getting into the cooling system and they work well.
http://buy1.snapon.com/catalog...talog
this is the one I use at work, you may be able to find them cheaper elsewhere.
WTF??? lol
Im in time, I have a new water pump, thermostat, the fan works and the coolant has been bleed. Theres also no water on the dip stick and the car isn't leaking any water anywhere. Any ideas?[/QUOTE]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowRSX »</TD></TR><TR><TD CLASS="quote">Im not sure why this car is still overheating. I replaced the water pump, I replaced the thermostat, I bleed the coolant multiple times and it seems like theres a never ending supply of air in the coolant. It never overheats just sitting idleing but when you go to drive it, then it over heats. I have my fan hardwired to come on when the ignition is switched on. The car is perfectly in time.
Im in time, I have a new water pump, thermostat, the fan works and the coolant has been bleed. Theres also no water on the dip stick and the car isn't leaking any water anywhere. Any ideas?</TD></TR></TABLE>
sounds like headgasket to me too.any water in the oil or oil in the water?and i hope they would be no water on the dip stick cause if they were that couldnt be a good thing.have u turned the heater core on and filled up all that **** too?hows fast does it over heat when u drive it?
wow my radiator use to do the samething.when driven at speed of 50 or over it will overheat.i mean u could sit there and watch the needle go up.then if i slow down it can see it go back to normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manoy »</TD></TR><TR><TD CLASS="quote">try replacing the radiator , (based on my xpirience) b4 puting the head down . better check it fist . </TD></TR></TABLE>
OR, open the rad cap and smell the coolant to see if it smells like exhaust. thats whats making you think you have air in your coolant when its really the pressurized exhaust gas in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">Did anybody read that he found the culprit?
Glad to hear you fixed it man
Thanks buddy
</TD></TR></TABLE>Thanks buddy
ive put 3 head gaskets on my d16a6...trust me its shot! but its no biggie to replace. i did all 3 of mine in 2 hours...of course i was stupid enough not to resurface the head. but ya know shortage of moolah makes u do stupid ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowRSX »</TD></TR><TR><TD CLASS="quote">some stupid mother expletiveers on this board. PROBLEM ALREADY expletiveING SOLVED, STOP RELPY WITH STUPID **** </TD></TR></TABLE>
or mabe you need to flush your radiat..... oh. sorry
maybe you should get an avatar so your posts stick out a little more
this coming from someone who doesnt use or even belive in a tq. wrech.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi »</TD></TR><TR><TD CLASS="quote">
this coming from someone who doesnt use or even belive in a tq. wrech.</TD></TR></TABLE>
lol atleast I own a torque wrench. Why do you always talk **** online? You know i'd stick you in the mouth if you were here and said that ****?
xCIVICxHATCHxSI
Sep 13, 2009 10:11 PM
nonvtec92
14
Nov 28, 2008 04:50 PM
Nameless Warrior
10
Dec 16, 2006 07:27 AM
dude when u told me u didnt belive in tq. specs why do u think i laughed at you?
hahaha
