Can i REUSE STOCK rod Bolts?
Old Dec 9, 2007 | 05:15 AM
b16a4's Avatar
Default Can i REUSE STOCK rod Bolts?
Engine, B16a
I am going to pull down my block to change RINGS alone,
no bearings.
New headgasket and arp head studs.
Can i reuse the stock Rod Bolts?
What do you guys Advise?
Old Dec 9, 2007 | 05:34 AM
DaveF's Avatar
Default Re: Can i REUSE STOCK rod Bolts? (b16a4)
get some arp rod bolts, they are cheap enough. you dont want a stretched rod bolt to destroy your day... do you ?
Old Dec 9, 2007 | 05:55 AM
b16a4's Avatar
Default Re: Can i REUSE STOCK rod Bolts? (DaveF)
my mechanic said my engine bearings are good.
do you recommend i change them?
he said there is no need to...
Old Dec 9, 2007 | 06:02 AM
non-VTEC's Avatar
for the extra insurance you might as well at least get new bearings......the rod bolt replacment requires sending the rods/pistons to the machine shop to have them pressed in and out etc....
Old Dec 9, 2007 | 06:26 AM
b16a4's Avatar
Default Re: Can i REUSE STOCK rod Bolts? (non-VTEC)
the stock rod bolts need to be pressed out?
Old Dec 9, 2007 | 06:44 AM
93supercoupe's Avatar
the stock rod bolts do need to be pressed out, but they shouldnt take too much force.
And changing engine bearings isnt for the novice, so if ur engine builder is good than do it, but beware it needs to bo done right.
Old Dec 9, 2007 | 05:36 PM
TheShodan's Avatar
Moderator
Default Re: Can i REUSE STOCK rod Bolts? (93supercoupe)
DO NOT USE the stock bolts again. get the right parts... you know this by now.
Old Dec 9, 2007 | 08:02 PM
b16a4's Avatar
Default Re: Can i REUSE STOCK rod Bolts? (TheShodan)
Old Dec 11, 2007 | 05:58 PM
eg6sirll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">Engine, B16a
?</TD></TR></TABLE>
just like you can reuse condoms.
2ndchirp
Jun 20, 2024 01:15 PM
turbohatch96y7
Feb 11, 2015 09:14 PM
DefiantGSR
Oct 25, 2008 11:07 AM
GSROWNSU
Apr 12, 2007 11:31 PM
Wazup
Mar 31, 2005 02:58 PM
