[DIY] Removing Car Window Tint
Old Dec 8, 2007 | 02:11 PM
djessenz's Avatar
Default [DIY] Removing Car Window Tint
Removing Window Tint
Well, this is basically my first DIY tutorial. I have been wanting to remove my old tint so I can put new 5% tint all around, but I'm a bit short on cash since I'm only 16! I thought hey, why don't I remove my tint myself, and save myself about $100-$150? And this is what I did! Thanks for reading, hopefully this will help YOU!
1) Start by gathering your items!
You are going to need
i) All-Purpose Spray Cleaner
ii) Garbage Bag
iii) Scissors
iv) Tape
v) Newspaper or similar
vi) Paper Towels
vii) Goo Gone
Start by masking just below the window.
Spray the inside of the window with windex, or similar.
Now grab your garbage bag.
Take the windex and spray the OUTSIDE of the window as well.
After spraying the window, place the garbage bag on top of the window and you can cut it to a decent fit. I used some tape because it was a little windy outside today.
Now let it sit for 20-30 minutes in the SUN!
When time is up, hop inside the car and with your knife and pick at the corner of it.
It might be stubborn, but keep picking at it and once you get a grip with your fingers you can start pulling!
Keep pulling!
My doggy
Clean-Up Time!
Grab your Goo Gone and preferably an old t-shirt of some sort.
Pour the Goo Gone onto the shirt, and scrub, stay persistent and you will see the left-over glue and residue starts to go away!
Once you do all of your windows, your car will end up like mine did!
Before
After
You have now successfully removed your tint without ruining your defroster and using any blades!
Congratulations
Old Dec 8, 2007 | 04:01 PM
slacks's Avatar
Default Re: [DIY] Removing Car Window Tint (djessenz)
Nice tutorial!
Looks like the Goo Gone worked a ton better than goof off when I did mine.
I'll have to try this when the other tint comes down.
Old Dec 8, 2007 | 04:04 PM
MF Doom's Avatar
trapped in my own room!
Default Re: [DIY] Removing Car Window Tint (slacks)
mos def in for when the sun comes back up
Old Dec 8, 2007 | 04:07 PM
RA122324's Avatar
This is a damn good DIY. Been thinking about removing my tint and having it redone come summertime.
Old Dec 8, 2007 | 04:08 PM
HeikDiesel's Avatar
So the garbage bag warms up the tint and makes it easier to remove?
Old Dec 8, 2007 | 04:26 PM
Sloshy's Avatar
Default Re: [DIY] Removing Car Window Tint (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">So the garbage bag warms up the tint and makes it easier to remove?</TD></TR></TABLE>
taht what i was thinking...
Old Dec 8, 2007 | 04:37 PM
blk92_d16's Avatar
Goo Gone &gt; Goof Off...good to know! I'll have some old tint to clean off myself if I get this EJ I want.
Thx
Old Dec 8, 2007 | 04:40 PM
zippo1130's Avatar
Is there any suggestions for deteriorated tint?
Old Dec 8, 2007 | 04:51 PM
djessenz's Avatar
Default Re: (zippo1130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zippo1130 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any suggestions for deteriorated tint? </TD></TR></TABLE>
Same thing applies, except it will not come off in one big peel!
Old Dec 8, 2007 | 05:45 PM
Neebs's Avatar
Did some of the defrost copper for the rear window come off?
Old Dec 8, 2007 | 06:11 PM
em1woot's Avatar
I use a razor to take off the tint, didnt use just the razor but the part the razor goes on. Took me about 30 to take off 3 windows. But still havent taken the rear off, beacuse of the defroster , Im going to try this on the rear.
thanks for the DIY
Old Dec 8, 2007 | 06:12 PM
Neebs's Avatar
^ Going to take you forever b/c of the defroster wires. Took me almost two hours to do my rear window.
Old Dec 8, 2007 | 09:55 PM
djessenz's Avatar
Default Re: (Neebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs &raquo;</TD></TR><TR><TD CLASS="quote">^ Going to take you forever b/c of the defroster wires. Took me almost two hours to do my rear window.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs &raquo;</TD></TR><TR><TD CLASS="quote">Did some of the defrost copper for the rear window come off?</TD></TR></TABLE>
No, my defroster works flawlessly! Nothing was damaged at all and I like this method a lot better than using a razor blade.
Old Dec 8, 2007 | 10:54 PM
b17 turbo's Avatar
Default Re: [DIY] Removing Car Window Tint (em1woot)
i use a razor also, peel the tint soak the residue thats on the window with some glass cleaner and wipe off with a towel for the back window i do the same but use some fine steel wool wipe the window and knock some of the glue off then just wipe with a towel the steel wool doesnt hurt the defroster
Old Dec 8, 2007 | 11:28 PM
Lasty K's Avatar
Ahh I wanna try this on mine, stupid rain!!!
Old Dec 8, 2007 | 11:41 PM
em1woot's Avatar
Default Re: (djessenz)
no, i meant im goin to try the way with the garbage bag,
Old Dec 8, 2007 | 11:43 PM
hectic57's Avatar
nice write up!
Old Dec 9, 2007 | 08:37 AM
djessenz's Avatar
Default Re: [DIY] Removing Car Window Tint (hectic57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lasty K &raquo;</TD></TR><TR><TD CLASS="quote">Ahh I wanna try this on mine, stupid rain!!!</TD></TR></TABLE>
Guys, this can be done with a blow dryer as well! Everything applies, except instead of letting it sit in the sun you heat the hell out of it with a blow-dryer.
Old Dec 9, 2007 | 08:38 AM
Lasty K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djessenz &raquo;</TD></TR><TR><TD CLASS="quote">
Guys, this can be done with a blow dryer as well! Everything applies, except instead of letting it sit in the sun you heat the hell out of it with a blow-dryer.</TD></TR></TABLE>
LOL, I was thinking of that this morning when I walked out to my car. Good stuff man.
Old Dec 9, 2007 | 08:43 AM
djessenz's Avatar
Default Re: [DIY] Removing Car Window Tint (Lasty K)
LOL, I was thinking of that this morning when I walked out to my car. Good stuff man. </TD></TR></TABLE>
Haha, what happened to me is that is wasn't that hot yesterday, and I wasn't really planning on doing my rear window. So I'm like whatever, the it was pretty cold now and the sun wasn't doing anything to the rear window so I grab an extension cord, my moms blow-dryer and get to work. It's REALLY easy, and not that time consuming at all.
P.S. I'm getting my car tinted today! Yay! 5% in the back and 10% in the front.
Old Dec 11, 2007 | 12:44 AM
JDM-ish's Avatar
this helped me ALOT! thanks!
Old Dec 11, 2007 | 02:19 AM
yoej8's Avatar
I've been wanting to replace my rear window tint. I've been putting it off just because of those damn defroster lines.
Thank you OP
Old Dec 11, 2007 | 06:06 AM
bubblevic's Avatar
Default Re: (yoej8)
great post
Old Dec 11, 2007 | 06:58 AM
TeeB16's Avatar
bump.........
Old Dec 12, 2007 | 04:11 PM
djessenz's Avatar
Default Re: (TeeB16)
Thanks guys
Hopefully this can be put in the FAQ section!
