HELP!! valve stem seal will not go on properly!
Old Dec 8, 2007 | 08:30 AM
LS AzZkIkr's Avatar
Default HELP!! valve stem seal will not go on properly!
i have a set of seals for a ls head and i am using them on a 00 si b16 head. i have searched all morning long and i have found no one with my problem. they seem to be too big and will not click into place. please help!!
Old Dec 8, 2007 | 10:19 AM
Jared's Avatar
thats because you have the wrong seals. the guide is a bigger od on the LS. get the right seals.
Old Dec 8, 2007 | 10:45 AM
quicksilver1689's Avatar
i ♥ snails
Default Re: HELP!! valve stem seal will not go on properly! (LS AzZkIkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS AzZkIkr &raquo;</TD></TR><TR><TD CLASS="quote">i have a set of seals for a ls head and i am using them on a 00 si b16 head. =</TD></TR></TABLE>
Old Dec 8, 2007 | 12:07 PM
LS AzZkIkr's Avatar
Default Re: HELP!! valve stem seal will not go on properly! (quicksilver1689)
https://honda-tech.com/zerothread?id=1676914
this post says any d/b series valve seals that they are all the same. thats where i have been getting my information from. but thanks for the correction i really appreciate it.
Old Dec 8, 2007 | 06:21 PM
Fkned's Avatar
Even if they did fit on the guide they wouldn't work because the valve stems are different sizes.Ls heads are 6.5mm(I think,it's been a while since I did an ls head)and B16-gsr are 5.5mm.Did you notice they have a bigger hole in them then the valve stem when trying to install?
Old Dec 8, 2007 | 06:29 PM
Muckman's Avatar
Moderator in Chief
If they were the same they would have the same part number.
93 ls
Apr 16, 2007 08:02 PM
pdiggitydogg
Nov 7, 2006 02:20 PM
b18CivicEx
Apr 30, 2005 10:12 AM
torr
Apr 24, 2003 10:06 AM
rocket_R
Jun 7, 2002 11:22 AM
