high12's whats needed
Old Jun 26, 2002 | 03:37 PM
goforbroke's Avatar
MEAT PATTY
Default high12's whats needed
I have a 1990 civic si with a b16a and DC 4-1 header. Should I sell that motor and buy a b18c1 motor and build that up or should I stay with my b16a. I know with bolt on's and slicks I could probably run high or mid 13 with the b16a. So what should I do. I'm going all motor.
Old Jun 26, 2002 | 03:40 PM
hybridreams's Avatar
Default Re: high12's whats needed (goforbroke)
C1.
Old Jun 26, 2002 | 07:41 PM
brian b's Avatar
New User
if you can get the weight down to like 2000, and find a way to make 230hp (high compression) youll run low 12's with a driver and tires
Old Jun 26, 2002 | 08:09 PM
flip1199's Avatar
Default Re: high12's whats needed (brian b)
Why not just build the b16 up and turbo it???
Old Jun 27, 2002 | 12:41 AM
ninesecrx's Avatar
Default Re: high12's whats needed (flip1199)
I will bet if you drop a turbo kit on the b16 motor and drive your car right with some slicks...you could net a 12 sec. et.
Old Jun 27, 2002 | 01:47 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: high12's whats needed (ninesecrx)
I was thinking the same thing. Those cars are very light and with the stock motor and some good tunning you can get into the 12's with maybe 10psi.
art
Old Jun 27, 2002 | 04:59 AM
Black SVT's Avatar
Default Re: high12's whats needed (Arturbo)
Nitrous will do it.A local guy here went 12.90 with same car,b16 and an 85 shot.
Old Jun 27, 2002 | 05:34 AM
ATYPR's Avatar
Default Re: high12's whats needed (Black SVT)
turbo kit
injectors
adjustable FMU
V-AFC
dyno time
Old Jun 27, 2002 | 07:17 AM
newsense's Avatar
New User
Since you are going all motor, I would suggest going with a b18c1 block, some high compression pistons, and the b16a head with some headwork and a nice valve train..... voila you have a built "Type R" motor. My homeboy did this and it went 12.80 in a full bodied coupe with full interior.
Old Jun 28, 2002 | 01:28 PM
jinxproof99's Avatar
New User
Default Re: high12's whats needed (newsense)
all motor: keep the head, add springs retainers and aggressive cams. get a ls block and bore it to 86mm. keep the b16 tranny. run 12's easy, probably on street tires.
turbo: get a drag kit, 440 injectors, inlinepro headgasket, race fuel, slicks, blah, blah,.........run 11's. on stock b16 block and ecu.
supercharger: why bother?!
CXtypeR
Apr 4, 2007 12:33 PM
schroddam
10
Jul 22, 2005 12:06 PM
TwoSaints
178
Feb 12, 2004 02:42 PM
gstintegra92
21
Nov 27, 2002 11:22 AM
MaD3 In JaPaN
Apr 25, 2002 11:49 PM
