resister box wiring question...
i was getting my resistor box wired up today and when we tested for the 12v wire in the plug we found none...now there are 4 reds and 1 yellow coming out of my plug and my resistor box...i assume the yellow would be the 12v wire...any body have any idea y it isnt reading anything on the volt meter..anyone had this problem...i had the key on when i tested too...
https://honda-tech.com/zero...age=1
https://honda-tech.com/zerothread?id=517274
there are others but that will get you started.
you wire in 4 10 wattt 10 ohm resistors in to each injector, 1 in every positive wire on injector. got off partsexpress.com i think that was it... or at radio shack if ur lucky.
bruthaboost
Dec 17, 2001 09:08 PM
