resister box wiring question...
Old Dec 7, 2007 | 06:32 PM
T9U4ReBgO's Avatar
Default resister box wiring question...
i was getting my resistor box wired up today and when we tested for the 12v wire in the plug we found none...now there are 4 reds and 1 yellow coming out of my plug and my resistor box...i assume the yellow would be the 12v wire...any body have any idea y it isnt reading anything on the volt meter..anyone had this problem...i had the key on when i tested too...
Old Dec 7, 2007 | 08:19 PM
roachsboosted16's Avatar
Default Re: resister box wiring question... (T9U4ReBgO)
instead of the resistor box u can wire in 4 10w 10ohm resistors, i did it today very easy.
Old Dec 8, 2007 | 03:38 AM
T9U4ReBgO's Avatar
Default Re: resister box wiring question... (roachsboosted16)
can u explain how...and where did u get the resistors...
Old Dec 8, 2007 | 08:03 AM
boostedcivicsir's Avatar
Mr. Badwrench
https://honda-tech.com/zero...age=1
https://honda-tech.com/zerothread?id=517274
there are others but that will get you started.
Old Dec 8, 2007 | 08:05 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
don't use resistors... use the resistor box
Old Dec 8, 2007 | 10:58 AM
T9U4ReBgO's Avatar
Default Re: (tannerLSt)
I know how to wire it up but don't understand y I am not getting 12v out of the dead end plug
Old Dec 8, 2007 | 06:36 PM
JaredKaragen's Avatar
Default Re: (T9U4ReBgO)
You need to have the key on to check it; Key on, engine off.
It's there.
Old Dec 8, 2007 | 06:38 PM
you wire in 4 10 wattt 10 ohm resistors in to each injector, 1 in every positive wire on injector. got off partsexpress.com i think that was it... or at radio shack if ur lucky.
mpf90
Mar 23, 2009 11:54 AM
rdssk8rcs1
Apr 10, 2008 08:52 AM
vladd
Aug 4, 2006 04:28 PM
fast[R]
Jun 11, 2004 03:19 PM
bruthaboost
Dec 17, 2001 09:08 PM
