ITR suspension.
ok i have jdm ITR suspension on my ej1 that i am looking to sell. my question is will it fit on an ek. and what i mean is would it bolt straight up to the ek and if not what would have to be done. i used the search feature but the only thing that came up was people trying to sell thier 5 lug. thanx for all the inputs.
The 5-lug setup will bolt onto a 96-00 Civic. The front and rear LCAs will not. The struts and springs will, only if you buy Function7 96-00 Civic "ITR style" LCAs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstatus95 »</TD></TR><TR><TD CLASS="quote">so i would be able to change the lca's correct?</TD></TR></TABLE>
You can't put ITR LCAs on a 96-00 Civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstatus95 »</TD></TR><TR><TD CLASS="quote">^^^ what i meant was swap out the itr lca's for the ek lca's.</TD></TR></TABLE>
If it doesn't work one way, it will surely won't work the other way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Everything is the same except for the rear lower control arms - the EK ones are completely different.</TD></TR></TABLE>
Sorry I was in a hurry and didn't complete my thought.
The rear struts are different too as in since the ITR rear struts have the eye hole in the bottom of them as opposed to the forks you can't even retain the EK lower control arms and use the ITR struts in the rear.
If you worried simply about the 5 lug itself then yeah the rear hubs can be swapped out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstatus95 »</TD></TR><TR><TD CLASS="quote">what about the front?</TD></TR></TABLE>
The entire knuckles/spindles bolt right up, but you must keep the EK Civic upper control arms. The struts interchange too, but the Integra struts have the brake hose brackets on them.
DBiNfEcTeD*
Jun 11, 2016 12:54 PM
