Fuel pump doesn't prime sometimes, searched
Usually when the weather is cold and my car has been sitting for a couple of hours, the fuel pump will not prime on the first try. Takes me a couple tries turning the key to get it to prime and then it will start up and run just fine. Could it be a bad main relay? Thanks.
bump, because ive had this problem. when i put my built motor in my walbro didnt kick on all the time, then i just worked all them time. now i have a stock motor i just put in my da with the walbro and it wont turn on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegman23 »</TD></TR><TR><TD CLASS="quote">bump, because ive had this problem. when i put my built motor in my walbro didnt kick on all the time, then i just worked all them time. now i have a stock motor i just put in my da with the walbro and it wont turn on...</TD></TR></TABLE>
Did you check your....
R-E-L-A-Y-?
R-E-L-A-Y-?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror »</TD></TR><TR><TD CLASS="quote">
R-E-L-A-Y-?
HAHAHA wow. you would think that they listen to you the first time right? jeez...
oh and yea. its definitely the relay.
R-E-L-A-Y-?
</TD></TR></TABLE>HAHAHA wow. you would think that they listen to you the first time right? jeez...
I resoldering my old one, there was a great write up on it somewhere but I don't remember where. It's REALLY simple. Just take it apart, heat up the old solder see if u can scrape it off, if not then just put on some new solder. It works great now!
CivicHP
Jul 15, 2007 11:46 PM
i dont think you can fix it?i have some extra if you want for sell just PM me...
