possible bent valve?
Old Dec 7, 2007 | 01:36 AM
aznxpyroboi's Avatar
Default possible bent valve?
ok i have a 96 integra b18 motor so i was dropping off my gf and came to a stop and as it came to a stop my rpms went extremely low then the car shut off.. i cranked it and it turned over but wouldnt start.. i cranked it all together probably for about 2 minutes took it to my mechanic said it was my timing belt.. so after he put in a new timing belt he said that i have one bent valve and when im driving the car runs well but when it comes to a stop and the rpms drop then come back up but sometimes it idles just fine but the car has to sit at the light for a minute until it drops up and down.. i know if the timing belt ripped as i was moving i would have bent a valve but i wasnt moving when the car shut off so could i have bent a valve that easily?
Old Dec 7, 2007 | 02:37 AM
ek4shizzle's Avatar
Default Re: possible bent valve? (aznxpyroboi)
yep. if the belt snaps while the engine is running it can possibly damage a valve. do a compression and leakdown test to be sure.
Old Dec 7, 2007 | 04:41 AM
AWD Terror's Avatar
Default Re: possible bent valve? (ek4shizzle)
I would bet bent vavles.
Why would your mechanic change the belt without looking/listening for bent valves?
Old Dec 7, 2007 | 07:51 AM
Fern413's Avatar
Default Re: possible bent valve? (AWD Terror)
do a compression test
Old Dec 7, 2007 | 07:57 AM
GSR-TRBO-DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">I would bet bent vavles.
Why would your mechanic change the belt without looking/listening for bent valves?</TD></TR></TABLE>that is a perfectly good ? to ask
Old Dec 7, 2007 | 10:25 AM
650teg's Avatar
Sure sounds like a bent valve. Did you over rev or miss a shift just prior to that problem?
Old Dec 7, 2007 | 10:47 AM
Default Re: (650teg)
the belt didnt snap the teeth got messed up and the belt got stuck and told me the valve got bent i dont know if he was lying to me so he can get me to replace the valve and spend 700 dollars so i dont know if he messed up on installing the belt
Old Dec 7, 2007 | 10:57 AM
AWD Terror's Avatar
Default Re: (aznxpyroboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznxpyroboi &raquo;</TD></TR><TR><TD CLASS="quote">the belt didnt snap the teeth got messed up and the belt got stuck and told me the valve got bent i dont know if he was lying to me so he can get me to replace the valve and spend 700 dollars so i dont know if he messed up on installing the belt </TD></TR></TABLE>
No. He's right.
90% of the time when your t-belt snaps or slips teeth, vavles bent.
How many miles are on your t-belt?
Old Dec 8, 2007 | 03:01 AM
Dogginator's Avatar
Daisy... Daisy...
You have a 96 with ODBII. Are you storing CELs 71-74 for misfires?
Old Dec 8, 2007 | 08:55 AM
QuickGuy's Avatar
When you where coming to a stop and your RPM's drop and your car died is likely where your belt broke.
Even tho it was low engine speed, thats enough on an interference motor to do significant damage.
Old Dec 8, 2007 | 10:14 PM
Default Re: (QuickGuy)
UPDATE
did a compression test
clyinder 1 - 210
cylinder 2 - 190
cylinder 3 - 180
cylinder 4 - 210
im not totally sure but isnt my compression suppost to be at 180?
Old Dec 9, 2007 | 01:16 AM
deegz's Avatar
bent valves looks like.
all compressions testers read different.
your looking for a relatively close set of numbers, when that far outta wack, motor is toast..
Old Dec 9, 2007 | 05:20 AM
Dogginator's Avatar
Daisy... Daisy...
Perform a valve adjustment and redo the compression test. Your numbers should be uniform.
Old Dec 9, 2007 | 10:15 AM
anyone?
Old Dec 11, 2007 | 09:10 AM
LSVTEC408's Avatar
It is not a bent valve, because if u had a bent valve u would read 0 compression in the cylinder...
your compression numbers are good
start by replacing or checking this items: plugs,wires,fuel filter.
Old Dec 11, 2007 | 09:28 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: possible bent valve? (LSVTEC408)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC408 &raquo;</TD></TR><TR><TD CLASS="quote">It is not a bent valve, because if u had a bent valve u would read 0 compression in the cylinder...</TD></TR></TABLE>
You can still have compression with bent or misadjusted valves. It will just be reduced.
Old Dec 11, 2007 | 09:42 AM
AWD Terror's Avatar
Default Re: possible bent valve? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
You can still have compression with bent or misadjusted valves. It will just be reduced.</TD></TR></TABLE>
Like 15% reduced
Old Dec 11, 2007 | 11:20 AM
LSVTEC408's Avatar
its possible..but i had a slight bent valve and had no compression..due to all the air escaping through the valve..but anyways good luck...
and if u had a bent valve your car would not hold idle at all...my .2 cents
Old Dec 11, 2007 | 11:23 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC408 &raquo;</TD></TR><TR><TD CLASS="quote">its possible..but i had a slight bent valve and had no compression..due to all the air escaping through the valve..but anyways good luck...
and if u had a bent valve your car would not hold idle at all...my .2 cents</TD></TR></TABLE>
They do idle like crap. OBDII will also throw codes 71-74. I asked th OP this earlier.
npoutre
Honda CR-V & Element
10
Jun 20, 2019 01:48 PM
ev94eg
Dec 10, 2012 05:43 PM
Charlie Moua
Dec 15, 2009 06:16 PM
young geezer
May 21, 2009 08:37 AM
Shannons52
Jul 14, 2003 07:25 PM
