Grinding 2nd.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K »</TD></TR><TR><TD CLASS="quote">slow your shifts into second. change fluid asap that will diminish the probability of it occuring. and finally check my sig for TSB. its a common ap1 issue. </TD></TR></TABLE>
putting the clutch in Helps sometimes
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">
putting the clutch in Helps sometimes</TD></TR></TABLE>
thats what i forgot to do... dammit, i knew it was something like that
My best recommendation is to change out your tranny fluid with Royal Purple synthetic syncromax. My AP1 did the same thing when I bought it with 35kmi on it and it no longer grinds. Not to mention it shifts much smoother and accurately.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA »</TD></TR><TR><TD CLASS="quote">
thats what i forgot to do... dammit, i knew it was something like that</TD></TR></TABLE>
i figured it would help!
thats what i forgot to do... dammit, i knew it was something like that</TD></TR></TABLE>i figured it would help!
i forget sometimes too lol
thats what i forgot to do... dammit, i knew it was something like that</TD></TR></TABLE>i forget sometimes too lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 »</TD></TR><TR><TD CLASS="quote">Hey guys, I have read that grinding 2nd gear on AP1's is common. Please help me fix this problem. How do I do it?</TD></TR></TABLE>
this has worked for me. i switched shift ***** to skunk2's heavier 440g and that helped shifting in all gears. also, for 2nd, going from first you have to pull straight down going into 2nd....DONT angle it diagnally down to the left.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K »</TD></TR><TR><TD CLASS="quote">This happens to me once in a while. I gotta change my fuild.</TD></TR></TABLE> WTF the ap1 has a clutch....i thought that only came in the AP2?? pfft well ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 »</TD></TR><TR><TD CLASS="quote">
this has worked for me. i switched shift ***** to skunk2's heavier 440g and that helped shifting in all gears. also, for 2nd, going from first you have to pull straight down going into 2nd....DONT angle it diagnally down to the left.</TD></TR></TABLE>
great, great shift ****. put it in my integra and it is gorgeous. i have a team voodoo in my S, but im seriously considering changing it out for the skunk2.
any other great shift ***** out there while we are on topic?
try double clutching. if it's your syncro, you can find out by doing this.
trooper0641
10
Jun 4, 2005 10:32 PM
vtec_racer_2kgsr
Sep 16, 2003 05:56 PM
