Honda S2000 Honda S2000
Grinding 2nd.
Old Dec 5, 2007 | 08:14 PM
wrice4's Avatar
Default Grinding 2nd.
Hey guys, I have read that grinding 2nd gear on AP1's is common. Please help me fix this problem. How do I do it?
Old Dec 5, 2007 | 08:29 PM
LAS2K's Avatar
Default Re: Grinding 2nd. (wrice4)
slow your shifts into second. change fluid asap that will diminish the probability of it occuring. and finally check my sig for TSB. its a common ap1 issue.
Old Dec 5, 2007 | 08:30 PM
wrice4's Avatar
thank you
Old Dec 6, 2007 | 05:08 AM
Black S2K's Avatar
This happens to me once in a while. I gotta change my fuild.
Old Dec 6, 2007 | 06:23 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">slow your shifts into second. change fluid asap that will diminish the probability of it occuring. and finally check my sig for TSB. its a common ap1 issue. </TD></TR></TABLE>
putting the clutch in Helps sometimes
Old Dec 6, 2007 | 06:52 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: Grinding 2nd. (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">
putting the clutch in Helps sometimes</TD></TR></TABLE>
thats what i forgot to do... dammit, i knew it was something like that
Old Dec 6, 2007 | 07:13 AM
TL1000R's Avatar
My best recommendation is to change out your tranny fluid with Royal Purple synthetic syncromax. My AP1 did the same thing when I bought it with 35kmi on it and it no longer grinds. Not to mention it shifts much smoother and accurately.
Old Dec 6, 2007 | 07:28 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Grinding 2nd. (S2KILLA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i forgot to do... dammit, i knew it was something like that</TD></TR></TABLE>
i figured it would help!
Old Dec 6, 2007 | 08:14 AM
wrice4's Avatar
ok thanks for the help guys...oh and ya i do press the cluth down...or so i think, dun dun dun
Old Dec 6, 2007 | 08:52 AM
ap1lvr's Avatar
Default Re: (wrice4)
i agree, run RP step on the clutch all the way and you will be good to go.
Old Dec 6, 2007 | 09:24 AM
TheDancingPill's Avatar
i forget sometimes too lol
Old Dec 6, 2007 | 05:43 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, I have read that grinding 2nd gear on AP1's is common. Please help me fix this problem. How do I do it?</TD></TR></TABLE>
this has worked for me. i switched shift ***** to skunk2's heavier 440g and that helped shifting in all gears. also, for 2nd, going from first you have to pull straight down going into 2nd....DONT angle it diagnally down to the left.
Old Dec 7, 2007 | 02:18 PM
6KVtec's Avatar
Default Re: Grinding 2nd. (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">This happens to me once in a while. I gotta change my fuild.</TD></TR></TABLE> WTF the ap1 has a clutch....i thought that only came in the AP2?? pfft well ****
Old Dec 8, 2007 | 09:32 PM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
this has worked for me. i switched shift ***** to skunk2's heavier 440g and that helped shifting in all gears. also, for 2nd, going from first you have to pull straight down going into 2nd....DONT angle it diagnally down to the left.</TD></TR></TABLE>
great, great shift ****. put it in my integra and it is gorgeous. i have a team voodoo in my S, but im seriously considering changing it out for the skunk2.
any other great shift ***** out there while we are on topic?
Old Dec 8, 2007 | 09:33 PM
try double clutching. if it's your syncro, you can find out by doing this.
jaysome01
Sep 19, 2008 11:53 AM
Aralliius
Aug 13, 2007 07:26 PM
98LS4dr
Dec 15, 2005 03:38 AM
trooper0641
10
Jun 4, 2005 10:32 PM
vtec_racer_2kgsr
Sep 16, 2003 05:56 PM
