b18b in DA9
Old Dec 5, 2007 | 06:56 PM
Homotor's Avatar
Default b18b in DA9
okay so im pulling the motor out of my hatchback which is a b18b and putting it into a 91 teg what changes would i have to make in order for it work?? like changing the distributor, engine wire harness, and ecu?? thanks for any help !
Old Dec 5, 2007 | 07:20 PM
onepoint6i's Avatar
Default Re: b18b in DA9 (Homotor)
so you want to go obd 1 on the chassis?
Old Dec 6, 2007 | 06:05 AM
Homotor's Avatar
Default Re: b18b in DA9 (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">so you want to go obd 1 on the chassis?</TD></TR></TABLE>
what would be the cheapest and easiest way? im kinda on a low budget..
Old Dec 6, 2007 | 05:57 PM
onepoint6i's Avatar
why not just keep it obd0 and just put the long block in there with the same ditributor, harness ecu etc..thats the cheapest and easiest way to go...
Old Dec 7, 2007 | 06:07 AM
Homotor's Avatar
well the thing is that i traded my brother n law shells and he is putting the b18a in an EF with ecu n everything cuz its already obd0... now i gotta pull the engine(B18b) out of my EG put it in the DA.. im not for sure if its obd1 or obd2.
hmm.. what would all i have to change on my engine to make it obd0? just the wire harness and the distributor and get the proper ecu? im sorry! im such a noob... but hey everyone gotta start somewhere
Old Dec 7, 2007 | 12:34 PM
onepoint6i's Avatar
yur eg is obd 1.....but yeah you need a wire harness, ecu and distributor..
Old Dec 7, 2007 | 02:08 PM
Homotor's Avatar
is that it aside from fuel, vaccum lines etc. to get it started? thanks for all your help!
Old Dec 7, 2007 | 04:34 PM
Billy_Bob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">why not just keep it obd0 and just put the long block in there with the same ditributor, harness ecu etc..thats the cheapest and easiest way to go...</TD></TR></TABLE>
+1
AdrenalineAngel
Oct 31, 2012 09:22 PM
AdrenalineAngel
Oct 27, 2012 08:25 PM
'92 HatchGuy
Feb 20, 2007 03:18 PM
DAlove
Aug 29, 2004 05:37 AM
iwouldHITit
Feb 19, 2003 09:10 PM
