Dumb Q
Old Dec 5, 2007 | 05:42 AM
mortificationrock's Avatar
Default Dumb Q
well whats up HT Well my dumb Q comes to why my friends D16A engine makes barely to no noise at all?And why does my engine make more noise?My engine makes a little ticking but it seems more nisy than my friends,whats up?My engine is a D15B Vtec just in case.
Old Dec 5, 2007 | 05:45 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Dumb Q (mortificationrock)
Adjust your valves, and make sure your using oil of the correct viscosity... and it has oil in it.
rleonekc's Avatar
You don't hear vtec untill about 5k Rpms.
Some engines are more quiet than others, thats all. It's not necessarily a bad thing.
Check to see if both of your idles are the same.
Old Dec 5, 2007 | 05:50 AM
Default Re: Dumb Q (rleonekc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc &raquo;</TD></TR><TR><TD CLASS="quote">You don't hear vtec untill about 5k Rpms.
Check to see if both of your idles are the same.</TD></TR></TABLE> Thanx for you help dude but what does<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc &raquo;</TD></TR><TR><TD CLASS="quote">You don't hear vtec untill about 5k Rpms.
</TD></TR></TABLE> Have to do with my Q? Anyways i just thought it was a bad thing cuz i also just swapped in this motor about 6 months ago.And by oil viscosity,what type is used on my engine?Sorry for all the noobness
Old Dec 5, 2007 | 05:53 AM
rleonekc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock &raquo;</TD></TR><TR><TD CLASS="quote"> Thanx for you help dude but what does Have to do with my Q? Anyways i just thought it was a bad thing cuz i also just swapped in this motor about 6 months ago.And by oil viscosity,what type is used on my engine?Sorry for all the noobness </TD></TR></TABLE>
It's ok, we are all here to answer questions and help you out..
You mentioned in your original post "My car is D15 Vtec, if it matters".
That's why I went ahead and mentioned about the vtec not hittin till around 5k RPMS
Old Dec 5, 2007 | 05:58 AM
That's why I went ahead and mentioned about the vtec not hittin till around 5k RPMS</TD></TR></TABLE> Oh ok well thanx anyways! Anyone else got some insight on this or how to do a valve lash adjustment and what tools i would need?Is it easy?I mean i have done basic swaps and **** so im tool handy
Old Dec 5, 2007 | 06:35 AM
SOHC_4dr's Avatar
and your D15B will make more noise in VTEC. your buddies dont have VTEC. which would make his quiter. and it is normal for slight ticking from a honda. especially when its cold
Old Dec 5, 2007 | 06:54 AM
Default Re: (SOHC_4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr &raquo;</TD></TR><TR><TD CLASS="quote">and your D15B will make more noise in VTEC. your buddies dont have VTEC. which would make his quiter. and it is normal for slight ticking from a honda. especially when its cold</TD></TR></TABLE> Fo yo info a JDM D16A is Vtec! So that wont matter.But seriously his **** is quieter than my Saturn Kinda Scary
Old Dec 5, 2007 | 06:59 AM
JDM_Frijoles's Avatar
Default Re: (mortificationrock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock &raquo;</TD></TR><TR><TD CLASS="quote"> Fo yo info a JDM D16A is Vtec! </TD></TR></TABLE> Were you serious?
Old Dec 5, 2007 | 07:02 AM
Default Re: (JDM_Frijoles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles &raquo;</TD></TR><TR><TD CLASS="quote"> Were you serious? </TD></TR></TABLE>WTF does that mean What are you trying to say?
Old Dec 5, 2007 | 08:20 AM
ddd4114's Avatar
JDM d16a = USDM d16z6
Old Dec 5, 2007 | 08:26 AM
Default Re: (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">JDM d16a = USDM d16z6</TD></TR></TABLE>
Tell that stupid
captainkush
Jul 30, 2007 07:42 AM
wrinkles
May 9, 2006 01:51 PM
dAng! Kris
Sep 17, 2003 07:13 PM
heddie
Jun 21, 2003 02:48 PM
whatcivic
Jun 6, 2003 07:13 AM
