Damn! I can't shift into reverse. Doesn't go into the gate!
Well, the last problem to fix on my Integra. haha ... never ends.
I can't shift into reverse. Meaning - I can't even get the shifter into the reverse gate. Basically, I push the shifter to the right and down ... and it doesn't go down!
All forward gears work though.
Any possible solutions?
I have absolutely no clue how this happened. I had the engine rebuilt, which took like 3 months, and then it doesn't go into reverse.
Now, I did have the car towed a few times when it was done. AAA was the towing company. I feel they might at fault. I may give them a call ...
I called up my local Acura dealership and A&H motorsports. Acura wouldn't even touch it. Said just to buy a new tranny. A&H said anywhere from $600 to $1800.
I can't even drive the car ... hah ... NO FREAKING REVERSE!
Where do you guys go for the tranny work?
Should I just sell my tranny and buy a used one?
Adam
Adam
did you try the first then reverse method, then try doing it with out the car being on and what do you get?
If it goes in while the car is off then start in in reverse just hold the clutch in and see what the result is.
did you try shift 1th and reverse ? or second and reverse?
if it ain't workin after you shift 1th or sec and then reverse
sorry man
Good Luck~*
sorry man
Good Luck~*
mine did that the other day..i would go into first then to reverse and still nothing...i just put it in neutral ..took of the e-brake , and let the car roll a little and then it went in after that.....
Sometimes I can't get it into reverse either, even after I have tried the "1st then reverse" and the "2nd then reverse", so what I have to do is take my foot off the clutch, and then step on it again, and it goes into reverse with ease.
cept none of us are in gainesville..
assdime: boca
me: st pete
D: orlando
Marc: orlando
Aleph: PA
Yack/et cetera: NC/VA..
Mine did this too... Acura first thought it was the syncros. Put new gears and Syncros in, and out it back together. Still wouldn't go in. Found out it was a slightly bend shift fork. Couldnt even see it by looking at it. Ryan
as most said the "1st to reverse" method should work.
Do what I do, push the car backwards!
Works every time
Craig - Who has to do that some times to avoid the missing teeth on his spoon fly
Yup, open the door, place left foot on ground, push
Works every time
Works every time
I tell you man, i much rather have broke my left... driving sucks the *** end of a donkey
Craig - Who's thinking of pulling out the skill saw when he gets home
If the We-Todd-Did-Racing tranny crew is available, we might look at it for "cheap"...
assdime: boca
me: st pete
D: orlando
Marc: orlando
Aleph: PA
assdime: boca
me: st pete
D: orlando
Marc: orlando
Aleph: PA
I know about the 1st to reverse method. I did it all the time. This time there is actually something wrong with the tranny.
all these replies and no one has suggested putting it in forth and then reverse? works every time for me.
try putting in reverse , then let the clucth out a little bit, and tap the gas .if that dont work then theres a issue. or if you have a short shifter try putting the stock one back on
assdime: boca
me: st pete
D: orlando
Marc: orlando
Aleph: PA
Well I am in Boca Raton for the summer.
assdime: boca
me: st pete
D: orlando
Marc: orlando
Aleph: PA
stupid fast
Nov 22, 2012 04:21 PM
freshrex4g
Oct 25, 2004 05:47 PM
