Dash insert question
Old Dec 3, 2007 | 04:01 PM
scuzz's Avatar
Default Dash insert question
I've been searching several sites, but can't find info on swapping my 95 DX dash insert for SI insert. I know they are the same size, but is there any additional wiring, or is all the wiring in dash for the swap?
Thanks guys.
Old Dec 3, 2007 | 06:06 PM
RIZOBIZERT's Avatar
Default Re: Dash insert question (scuzz)
I'm confused about the word 'insert'. Do you mean gauge cluster? If so, plugs right up.
Old Dec 4, 2007 | 03:37 AM
scuzz's Avatar
Default Re: Dash insert question (RIZOBIZERT)
Sorry about confusion.
Yeah, the guage cluster.
I didn't know if I would have to wire the tach or not, since the DX doesn't have one.
I was hoping the harness was the same and had the wiring already there.
Thanks guys.
Old Dec 4, 2007 | 04:55 AM
RIZOBIZERT's Avatar
I'm not sure if you'll have to wire the tach, but if that's all, you've got it made. Typically Honda doesn't make different wiring harnesses for different models. It's cheaper and much better from a mass production standpoint to make one harness and just have one with a wire that goes to nothing (like your current cluster). If you need to wire the tach, it's not difficult. I believe you only have to run one wire. I had an 87 Nissan Stanza and simply pulled the signal from the distributor. If you'd like a tach and that nice stock look, pick up a cluster and plug it in. The worst case scenario is you'll have to run a wire (3 tops) to get the tach working, but I'm almost positive it's plug and play. Good luck.
Old Dec 4, 2007 | 04:58 AM
BryanM.'s Avatar
Resident Gearhead
The tach will work, done it before.
Old Dec 4, 2007 | 09:38 AM
scuzz's Avatar
Default Re: Dash insert question (mcvtec)
Thanks a ton guys. I've worked on American cars all my life and this Honda stuff is new and confusing.
I'm getting the hang of a lot of stuff thanks to reading and posting here.
Again, thanks.
Ron
Old Dec 5, 2007 | 03:18 PM
scuzz's Avatar
By the way, what's the easiest way to get the plastic surround that houses the cluster and vents out?
I took one out at the junk yard where I got my SI cluster and broke it.
Old Dec 5, 2007 | 04:42 PM
Crasian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuzz &raquo;</TD></TR><TR><TD CLASS="quote">By the way, what's the easiest way to get the plastic surround that houses the cluster and vents out?
I took one out at the junk yard where I got my SI cluster and broke it.</TD></TR></TABLE>
easiest way is by removing all 3 screws including the one behind the hazard switch and start gently pulling from the left side first. Make sure its not cold out, it'll be more prone to breaking.
Old Dec 7, 2007 | 02:57 PM
scuzz's Avatar
Default Re: Dash insert question (Crasian)
I must have missed one of the screws on the junk yard unit. I took out two screws over the cluster.
Thanks for the tip.
Old Dec 7, 2007 | 05:08 PM
NOFX's Avatar
H-T White Ops
Here's directions for removing the gauge cluster next time.
Old Dec 8, 2007 | 05:25 AM
scuzz's Avatar
Default Re: (NOFX)
Wow, thanks. I do see where I screwed up.
I ordered a manual yesterday so I wouldn't be so dumb.
A huge favor to me guys.
Ron
plsarestupid
Jun 30, 2011 05:33 AM
dfn_doe
Feb 3, 2006 04:22 PM
civiccrazy93
Jan 5, 2005 10:33 AM
MIdoriEK
Apr 3, 2002 11:46 PM
B19CivicHB
Oct 31, 2001 09:53 AM
