ECU upgrade
Old Dec 3, 2007 | 12:34 PM
ppg97ek's Avatar
Default ECU upgrade
Guys, I am looking to do some kind of upgrades to my D16y8. I plan to add more air, fuel, spark, cams etc etc. What options do I have & wut routes can I go easy simple and effective
Old Dec 6, 2007 | 01:17 PM
integrag's Avatar
if you want to adjust your a/f get an afc or and vafc or a safc etc...but get a chipped ecu to do everything else and get a msd ignition if you want to do your ignition
Old Dec 6, 2007 | 02:19 PM
Relic1's Avatar
convert to OBD1, drop in a chipped P28, have it tuned.
Note the above upgrades should be done all at the same time.
if you have to remain OBD2 for some reason then the AFC/VAFC/SAFC's are the only route you can go. But it will fall far from the potential of the chipped/tuned OBD1 ECU.
Old Dec 6, 2007 | 10:40 PM
mtber's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">convert to OBD1, drop in a chipped P28, have it tuned.
if you have to remain OBD2 for some reason then the AFC/VAFC/SAFC's are the only route you can go. But it will fall far from the potential of the chipped/tuned OBD1 ECU.</TD></TR></TABLE>
Old Dec 8, 2007 | 05:21 PM
integrag's Avatar
i went with a chipped p28 ecu and a vafc lol but yes relic1 is right that will fall far from converting to obd1
the_wholesaler
Apr 8, 2014 11:26 AM
MurtazaDSM
Engine Management and Tuning
Dec 23, 2010 08:25 PM
Mhollaek9
Jun 23, 2007 07:21 PM
viet_sensationz
May 26, 2007 06:33 PM
MaxxdoutSRT4_EK9
Jun 26, 2005 10:23 PM
