wat could it be ??????
the other day i was drivin and everthing shut off...the car had no power at all...i figured it was the alternator so i went and got a used one....i put it in and still there was no power....i went and go my old alternator checked they said it was still good so i checked my battery relay and it was blow i got a new one of thos and it started up ....the next day i tryed to drive it and it had a bad idle and when i hit the gas it had no power then it shut off and wouldnt start....wat could it be ????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr116 »</TD></TR><TR><TD CLASS="quote">the other day i was drivin and everthing shut off...the car had no power at all...i figured it was the alternator so i went and got a used one....i put it in and still there was no power....i went and go my old alternator checked they said it was still good so i checked my battery relay and it was blow i got a new one of thos and it started up ....the next day i tryed to drive it and it had a bad idle and when i hit the gas it had no power then it shut off and wouldnt start....wat could it be ???? </TD></TR></TABLE>
It could be a lot of things. First I would start by properly punctuating and breaking up your sentences for a legible question. Four periods =/= the end of a sentence. Are you cutting out important pieces of information from your question?
I would suspesitse you have a wiring problem.
umm if your just driving around and it keeps shutting off check your main relay.....also it could be your dizzy as well......granted it could be lots of things like the other guy said but by the sound of things those two sound like your best bet.
13BT
16
Dec 14, 2004 03:47 PM
