Is it normal to see a light trace of smoke from catchcan breather after a run?
Old Dec 2, 2007 | 06:52 AM
jetlude's Avatar
Default Is it normal to see a light trace of smoke from catchcan breather after a run?
Just installed one, never had one before.
Old Dec 2, 2007 | 07:14 AM
turbodohcsi's Avatar
how do you have it hooked up?
Old Dec 2, 2007 | 11:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (turbodohcsi)
depends on the severity, but a little is normal. how much oil are you passing and where is it hooked up at?
Old Dec 2, 2007 | 11:44 AM
oscarmayer's Avatar
ususally YES.
Old Dec 2, 2007 | 02:39 PM
blackeg's Avatar
Default Re: (oscarmayer)
yea my car would smoke/steam a little out of it during dyno pulls. i wouldnt get any oil in it, but it would have some smoke out of it. car had 10% or less leakdown and 195 even compression so it was healty
Old Dec 2, 2007 | 03:40 PM
jetlude's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">depends on the severity, but a little is normal. how much oil are you passing and where is it hooked up at?</TD></TR></TABLE>
I am using the two stock ports on valve cover (H22)as vent source. I dont have a return to the block, just a drain valve. Actually no oil in it so far (15psi)
kihun_cha
Jan 2, 2006 07:45 AM
igo4bmx
Jun 9, 2005 07:17 AM
anothersickhatch
Mar 25, 2004 08:47 PM
ItzTw
Dec 16, 2003 09:15 PM
Excelerate
Sep 21, 2003 09:26 PM
