Boosted B16a, Blue smoke out exhaust
Old Nov 30, 2007 | 05:55 PM
b16a4's Avatar
Default Boosted B16a, Blue smoke out exhaust
Setup is
Stock B16a
Silver Surver [60-1] Turbo
Precision Intercooler
Tial Wg+Bov.
Problem is, I am burning oil out the tail pipe....
Could it be because i need a oil restrictor on the turbo?
Or
Are my rings done?
Old Nov 30, 2007 | 05:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Boosted B16a, Blue smoke out exhaust (b16a4)
relax, breathe.
look in the cold side of the turbo for oil.
look at the hot side of the turbo for oil.
does the car run ok?
no?
then:
compression and leak down.
what line size are you running. -3 can live w/o a restrictor. -4 needs one.
Old Nov 30, 2007 | 06:04 PM
b16a4's Avatar
Default Re: Boosted B16a, Blue smoke out exhaust (boostedcivicsir)
No oil in either parts of turbo.
car runs okay....
213whp on 6psi.
ARF all over the place tho.. need to get it sorted out....
will do a compression test soon enuff....
mechanic said rings are done.
Old Nov 30, 2007 | 06:06 PM
b16a4's Avatar
Car also breaks up.......
like arround 5-6k rpm if i granny shift then accelerate..
What could cause the breaking up
running heat range 6 ngk.
bkr i think
Old Nov 30, 2007 | 06:07 PM
Mr. Badwrench
very possible.
Old Nov 30, 2007 | 06:20 PM
b16a4's Avatar
what could cause the breaking up?
Old Nov 30, 2007 | 06:21 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">
ARF all over the place tho.. need to get it sorted out....</TD></TR></TABLE>
start there.
Old Nov 30, 2007 | 09:32 PM
vti2's Avatar
You need colder plugs would say 7s wit .28 gap
Old Dec 1, 2007 | 05:49 AM
mrx's Avatar
mrx
Default Re: Boosted B16a, Blue smoke out exhaust (vti2)
For 6psi you don't need more then heatrange 6, at least it has nothing to do with your current problem. For that kind of HP they are fine if you are not running damn agressive timing on high cr. &gt; 10:1
first make a leakdown and compression test and see from where your oil is coming, if your rings are gone, you don't need to spend any time in tuning your afr because you have to rebuild anyway, so you can do a good tuning with your rebuild block.
if everything is fine, first make your afr's clean, mybe thats allready your breakup problem in some rpm's. And check your ignition timing, maybe it has a reason why your rings are gone (it could be possible that it is just of the age of your engine) but if not, i guess you have a tuning problem or just very bad luck.
GsrIntegra789
Aug 13, 2008 08:08 AM
buddy4002
10
Mar 27, 2006 10:48 PM
JeffRocksYoSocks
Jun 21, 2005 08:57 AM
malaya
Feb 25, 2005 06:01 PM
redline201
Sep 3, 2003 10:24 PM
