proper way to HONE
Old Nov 30, 2007 | 11:49 AM
92integraVTECgsr's Avatar
Default proper way to HONE
who has done their own hone job?
I'm going to be replacing the rings in my b18c1 and I want to do a hone. But what is the BEST most popular honing tool used?
and what is the proper technique?
I know just have to keep the drill/tool moving up and down evenly.. but how long do i need to do it for? do i need to be putting and oil or wd-40 or any other lube? also what grit stones to use? or is there something better to use?
any help would be greatly appreciated.
Old Nov 30, 2007 | 12:24 PM
hellakapps's Avatar
Default Re: proper way to HONE (92integraVTECgsr)
http://www.aa1car.com/library/2000/ar90058.htm
sorry if it's a bit more than you were hoping from, i hope it helps
Old Nov 30, 2007 | 12:31 PM
CerealKiller's Avatar
why not let a local shop do it? I wouldn't suggest doing it yourself if you are not 100% sure on what you're doing. Just my .02
Old Nov 30, 2007 | 01:20 PM
Default Re: proper way to HONE (CerealKiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CerealKiller &raquo;</TD></TR><TR><TD CLASS="quote">why not let a local shop do it? I wouldn't suggest doing it yourself if you are not 100% sure on what you're doing. Just my .02</TD></TR></TABLE>
I might just do that.. but the engine is going to be in the car. im just taking the head of and doing a semi rebuild while the motor is in the car.
Old Nov 30, 2007 | 01:55 PM
hellakapps's Avatar
you don't want to hone unless it's a bare block, you'll get metal and stone particals in the bottom end..if your not pulling the motor i'd leave the cylinders alone
Old Dec 1, 2007 | 10:12 PM
civic.slow's Avatar
* B A N N E D *
Default Re: proper way to HONE (hellakapps)
i like the 3 stone cutting tools, but if you're a newby i wouldnt suggest doing it yourself
most people like the multi ball hone i hate those ******* things
make sure to use cutting oil and make sure you get 60 degreee intersections at a fresh clean metal layer, put the motor together quick............***** IRON rusts like a bitch (ask me how i know)
Old Dec 2, 2007 | 04:27 PM
postman's Avatar
Default Re: proper way to HONE (civic.slow)
up and down with a steady speed making good crosshatch pattern. half and half mix oil and atf.
parasonic
Welding / Fabrication
Oct 26, 2008 06:56 PM
hondakid94
Sep 19, 2008 06:05 PM
accordlover
Nov 26, 2005 12:19 PM
accordredliner
13
Sep 18, 2005 08:19 AM
RCautoworks
15
Dec 3, 2004 12:51 PM
