dumb transmission grind(s)
Old Nov 29, 2007 | 11:46 PM
Fat Chick Magnet's Avatar
Default dumb transmission grind(s)
I just did a ITR swap and for my first time testing it out.. it didn't go into 3rd gear at low rpm(s) and didn't go into 4th gear as smooth and 5th gear wasn't great at all. 3rd gear would pop out sometimes and i never changed the transmission fluid, but does anyone recommend me to change the fluid to GM synchromesh or should i get in touch and try to get a replacement transmission with warranty?
Old Nov 30, 2007 | 12:00 AM
an2ny888's Avatar
Default Re: dumb transmission grind(s) (Fat Chick Magnet)
i would check fluid level first, it might be low. i've tried gm synchromesh and it worked fo me, made shifts a bit smoother
Old Nov 30, 2007 | 01:52 AM
tartje's Avatar
Default Re: (Fat Chick Magnet)
AFAIK you need more than a quart to fill a transmission
Old Nov 30, 2007 | 02:12 AM
tartje's Avatar
thats why i would have waited until one was open before i went for a drive
Old Nov 30, 2007 | 02:27 AM
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">thats why i would have waited until one was open before i went for a drive </TD></TR></TABLE>
yeah i could of done that, but without knowing if my transmission was KO or still in working condition i don't think i would of been able to sleep at night.
Old Nov 30, 2007 | 02:32 AM
tartje's Avatar
a fair point
Old Nov 30, 2007 | 03:22 AM
Dan GSR's Avatar
any oil is better than no oil
should have put some motor oil in there
Old Nov 30, 2007 | 07:09 AM
citrus3000psi's Avatar
So let me get this straight? You did a ITR swap into your car and didn't add fluid into the transmission?
Old Nov 30, 2007 | 08:04 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">i had 1 quart of Honda manual transmission fluid and filled it in there and i started my car up and the transmission was making a crunchy sound for a few seconds and i went driving off and after i hit the freeway my gears were working ok (as in no more grinds and pop outs) but i hope i didn't fry up the LSD or mess anything up.</TD></TR></TABLE>
that's about as smart as having unprotected sex with a girl that has herpes
Old Nov 30, 2007 | 08:09 AM
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
that's about as smart as having unprotected sex with a girl that has herpes</TD></TR></TABLE>
So your saying you would have protected sex with a girl with herpes?
Old Nov 30, 2007 | 08:19 AM
Mugen Mike's Avatar
Default Re: (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">
So your saying you would have protected sex with a girl with herpes?</TD></TR></TABLE>
LOL, no. But I definitely wouldn't have UNPROTECTED sex with her.
Old Nov 30, 2007 | 08:20 AM
JOHN WAYNE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">OK so its 2 A.M i just drained transmission fluid out and there was only 1/4 of a quart in there.
little bit of tiny shavings came out.. hopefully nothing bad happen, but i had 1 quart of Honda manual transmission fluid and filled it in there and i started my car up and the transmission was making a crunchy sound for a few seconds and i went driving off and after i hit the freeway my gears were working ok (as in no more grinds and pop outs) but i hope i didn't fry up the LSD or mess anything up.</TD></TR></TABLE>
sounds like you might need to throw your GSR engine back in there
Old Nov 30, 2007 | 09:04 AM
JjuuN R's Avatar
Default Re: (JOHN WAYNE)
YUCK LOL!!!
Old Nov 30, 2007 | 11:42 AM
well i have buddyclub spec 2 exhaust so i didn't want to wake people up around the streets and i hit freeway driving normal shifting under 3k rpm so my motor/tranny warms up quicker.
Old Nov 30, 2007 | 06:59 PM
Dan GSR's Avatar
should have changed the fluid, as part of the swap process
shame on you
Old Nov 30, 2007 | 07:11 PM
Doostur's Avatar
Ayyyyy no baby lotion
Old Nov 30, 2007 | 09:09 PM
PROBLEM FIXED.
/THREAD
Old Dec 1, 2007 | 01:58 AM
shorsh's Avatar
Old Dec 1, 2007 | 06:51 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (shorsh)
wow...simply retarded.
BTW...I finally got my engine in my car, but I didnt have any oil, so I fired it up real quick to make it run
Old Dec 5, 2007 | 10:59 AM
Default Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">wow...simply retarded.
BTW...I finally got my engine in my car, but I didnt have any oil, so I fired it up real quick to make it run </TD></TR></TABLE>
Oil pressure is for ******.
TypeGSR196
Jun 7, 2006 05:03 AM
209typer
Oct 3, 2004 01:54 PM
T-sohctec
Apr 25, 2004 10:29 PM
chuteBOXE
Apr 13, 2003 02:34 PM
geminis2k
Feb 23, 2003 12:53 PM
