Suspension & Brakes Theory, alignment, spring rates....
H&R sports with no Spring compressor?
Old Nov 29, 2007 | 11:01 PM
bobmugen's Avatar
Default H&R sports with no Spring compressor?
I just picked up some h&r sport springs from my friend and one of my other friends said that you can install h&rs without a spring compressor. He said to unbolt the top and slowly jack it up. My friend said it could work but it might pop. So should i do that method or find a spring compressor because i have been riding on one h&r for awhile and want the rest done.
Old Nov 30, 2007 | 06:12 AM
EK_B's Avatar
Just take caution and rent one for FREE.
Old Nov 30, 2007 | 07:24 AM
bobmugen's Avatar
how much does it cost at autozone
Old Nov 30, 2007 | 07:40 AM
Maireeka's Avatar
Default Re: (bobmugen)
it's like a 35 dollar (dont quote me but its around that) deposit that you get back when you return them.
Old Nov 30, 2007 | 08:03 PM
EK_B's Avatar
It's around $43 at Vatozone lol
Old Dec 1, 2007 | 09:58 AM
FredoTheChimp's Avatar
Default Re: (EK_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B &raquo;</TD></TR><TR><TD CLASS="quote">It's around $43 at Vatozone lol
Harbor Freight Tools sells them for 15 bucks or so.
Old Dec 2, 2007 | 11:21 AM
EK_B's Avatar
Default Re: (FredoTheChimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoTheChimp &raquo;</TD></TR><TR><TD CLASS="quote">
Harbor Freight Tools sells them for 15 bucks or so.</TD></TR></TABLE>
Yes they are the good ones too that has an actual hook!
Old Dec 2, 2007 | 12:12 PM
crexer's Avatar
Default Re: (EK_B)
have a friend stand on the sping in the grass when removing the top hat and things will work out fine. I have never used a spring compressor and done about 100 sping swaps.
Old Dec 2, 2007 | 03:16 PM
gnar kill's Avatar
Default Re: (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">have a friend stand on the sping in the grass when removing the top hat and things will work out fine. I have never used a spring compressor and done about 100 sping swaps.</TD></TR></TABLE>
me too I just stick my foot on it and use an air gun and it works fine
Old Dec 2, 2007 | 04:58 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (gnar kill)
If you get both off, you could duel at 10 paces like my brother and I do. Usually you won't hit each other.
Old Dec 3, 2007 | 06:28 AM
EK_B's Avatar
Oh man, are spring compressors overkill now?
Old Dec 3, 2007 | 07:12 AM
crexer's Avatar
Default Re: (EK_B)
you just dont need em dude, maybe for your dads f150 but not a honda spring. heck our springs are so small its tough just to use a compressor
Old Dec 4, 2007 | 08:00 AM
EK_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">you just dont need em dude, maybe for your dads f150 but not a honda spring. heck our springs are so small its tough just to use a compressor</TD></TR></TABLE>
Yeah that's true, I really couldn't get the Autozone ones on, so I had to go to Harbor Freight to buy the ones that would fit.
Old Dec 8, 2007 | 04:26 AM
punk_0333's Avatar
Default Re: H&R sports with no Spring compressor? (bobmugen)
You dont need a compressor to get the springs on. I just pulled down slightly on the top hat while someone else threaded the nut.
Old Dec 13, 2007 | 11:33 PM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: H&R sports with no Spring compressor? (punk_0333)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punk_0333 &raquo;</TD></TR><TR><TD CLASS="quote">You dont need a compressor to get the springs on. I just pulled down slightly on the top hat while someone else threaded the nut. </TD></TR></TABLE> Thats not safe, what i did was put my car on jacks and than get a jack and raised my lower control arm up untill my spring was getting compressed and than unscrewed the top hat bolt and than released my lca's slowly to the ground and that was as safe as i can tell you. But still a wrong way to do it..
Old Dec 14, 2007 | 08:08 AM
EK_B's Avatar
Default Re: H&R sports with no Spring compressor? (PinoyDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol &raquo;</TD></TR><TR><TD CLASS="quote"> Thats not safe, what i did was put my car on jacks and than get a jack and raised my lower control arm up untill my spring was getting compressed and than unscrewed the top hat bolt and than released my lca's slowly to the ground and that was as safe as i can tell you. But still a wrong way to do it.. </TD></TR></TABLE>
That way didn't work for me, was hard to do.
Old Dec 14, 2007 | 10:40 AM
* B A N N E D *
Default Re: H&R sports with no Spring compressor? (EK_B)
What way did you do?
Old Dec 14, 2007 | 05:09 PM
EK_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol &raquo;</TD></TR><TR><TD CLASS="quote">What way did you do?</TD></TR></TABLE>
Tried it your way, didn't work.
So I pressed the top hat down while my brother put the nut on.
Old Dec 15, 2007 | 12:16 AM
* B A N N E D *
So I pressed the top hat down while my brother put the nut on. </TD></TR></TABLE>That must of been tough for you guys huh?
Old Dec 15, 2007 | 06:56 AM
EK_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol &raquo;</TD></TR><TR><TD CLASS="quote">That must of been tough for you guys huh?</TD></TR></TABLE>
Kind of haha, I'm weak, need to work out.
mike9571
Nov 28, 2005 01:12 PM
WHiTETYPEs
Suspension & Brakes
20
Feb 4, 2005 10:26 PM
Pariah
Jun 9, 2004 07:10 AM
mikestypeR
Jan 15, 2004 05:29 PM
Kirei
Oct 5, 2003 08:30 PM
