Griding sound from front right wheel well during turns..
Old Nov 29, 2007 | 07:47 PM
BiG_DeE's Avatar
Default Griding sound from front right wheel well during turns..
only on hard left turns and going in reverse turning left or right. it makes this grinding sound from the front right wheel well anyone got some ideas??? its sitting on red springs that look like egay h&r wannabes, but i can move them when the car is on jack and wheel is taken off, so they possibly cut?? also car leans to left a bit thanks!
Old Nov 29, 2007 | 08:12 PM
EKstacy's Avatar
Default Re: Griding sound from front right wheel well during turns.. (BiG_DeE)
Sounds to me like the grinding noise could be your CV axles. My crx made a grinding noise only when turning and i had to have both replaced. On the leaning problem, id have to say that the springs may have just not been worth anything in the first place. Check all around and make sure all 4 match. The could be coilovers and that one wasnt put in correct.
Old Nov 30, 2007 | 03:18 PM
BiG_DeE's Avatar
bump - ne ideas?? there not coils...
Old Nov 30, 2007 | 03:22 PM
Neebs's Avatar
Are you rubbing? Check to see if you're rubbing in any area?
Old Nov 30, 2007 | 04:40 PM
BiG_DeE's Avatar
Default Re: (Neebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs &raquo;</TD></TR><TR><TD CLASS="quote">Are you rubbing? Check to see if you're rubbing in any area?</TD></TR></TABLE>
def not rubbing, it kinda sounds like a spring is doing something its not supposed to..
Old Nov 30, 2007 | 04:46 PM
Neebs's Avatar
Might be the wheel bearing.
Old Nov 30, 2007 | 05:07 PM
REAL TIME's Avatar
Default Re: (Neebs)
brake job recently? check the brake dust shield. or your brake pads worn out? I know it happens on turns but anything is possible
Old Nov 30, 2007 | 05:15 PM
BiG_DeE's Avatar
Default Re: (Neebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs &raquo;</TD></TR><TR><TD CLASS="quote">Might be the wheel bearing.</TD></TR></TABLE>
when i lifted car on jack i tried to wiggle the wheel, not the bearing.
midnyte
Suspension & Brakes
38
Jun 5, 2009 01:29 PM
MrDomino
May 26, 2008 12:11 PM
jefe
Feb 11, 2007 05:03 PM
Don Jefe
Apr 12, 2006 01:31 PM
noob
Jan 31, 2005 03:38 PM
