Need help choosing injector size
Old Nov 29, 2007 | 06:02 PM
carrnut21's Avatar
Default Need help choosing injector size
I cant decide what size of injectors to get. I am looking for 300whp out of my GSR on a stock B18C1. I will be using a Garrett t3/t4.
I know the RC 550 saturated injectors will get me to my goal, but later I plan on building the engine and am looking for 400+ whp. Should I go with 750's now so i don't have to upgrade later? Will the 750's have any negative effects if I run them to only support 300whp?
http://www.hondamarketplace.com/zerothread/1388343
they are only ten dollars more here.
Also, what cars do the plug and play injector clips work with? I will have to put my OEM injectors back in for emissions hopefully those will ease that process.
Thanks alot
Old Nov 29, 2007 | 06:42 PM
xenocron's Avatar
Default Re: Need help choosing injector size (carrnut21)
Buy the injectors now for your goals now...bigger injectors will, but I am a big believer in sizing for your goals now, not for the future.
OBD2 plug n play injector clips are for installing aftermarket (RC/Precision) injectors into an OBD2 Honda (1996+)
Old Nov 29, 2007 | 10:15 PM
carrnut21's Avatar
if i run 750's now what will the problems be? uneven idle, running less smooth at small throttle openings?
Old Nov 30, 2007 | 04:51 AM
fresh_manny21's Avatar
Default Re: (carrnut21)
I had 1000's on my car my goal was 450whp. I made 470whp on my stock block with big injectors and the car ran fine
I would say get the 750's and a good tune and you should be fine. Its all in the tune.
bigsnorlax
Mar 26, 2011 07:22 AM
01_ITR
Apr 8, 2009 03:29 AM
cvkid15
Engine Management and Tuning
Jul 4, 2008 09:04 AM
boostedlude3g
Jun 25, 2003 08:22 AM
kaneda3
Dec 30, 2002 12:18 PM
