Please HELP
Old Nov 29, 2007 | 05:48 AM
98jdmek's Avatar
Default Please HELP
ok my distributor went on me the other day right after i put sea foam in my motor to clean it out. i put my friends distributor on my car to make sure that was the problem and the car started right up. 2 days later i got a new distributor and put it on the car and now the car sounds like it has no compression. it turns over really fast and it sounds the same without the spark plugs in it as it does with them in. i havnt touched the car since i started it up with my friends distributor and it ran fine. i cannot think of wat could possibly hav went wrong because i didnt do anythhing to the car. anyone have any suggestions
Old Nov 29, 2007 | 06:14 AM
AWD Terror's Avatar
Default Re: Please HELP (98jdmek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98jdmek &raquo;</TD></TR><TR><TD CLASS="quote">car sounds like it has no compression.</TD></TR></TABLE>
Do a compression test to make sure.
Old Nov 29, 2007 | 06:43 AM
rleonekc's Avatar
Default Re: Please HELP (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
X2
Old Nov 29, 2007 | 07:13 AM
SOHC_4dr's Avatar
you may have put the dizzy 180 degrees off on the timing. the plugs aren't fireing when they are supposed to. what is the car?
Old Nov 29, 2007 | 07:23 AM
98jdmek's Avatar
Default Re: (SOHC_4dr)
its a 2001 ls in a 92 hatch so i already checked if i put the dizzy on backwards. i put it o both ways and i got the same thing
Old Nov 29, 2007 | 07:31 AM
AWD Terror's Avatar
Default Re: (98jdmek)
Do a compression test first.
If all is good, then put your friends distributor back on and see what happens.
Old Nov 29, 2007 | 11:30 AM
98jdmek's Avatar
im gonna hav to wait to do that till tomarro but is there anything else anyone can think of. has anyone heard of this happening b4?
Old Nov 29, 2007 | 01:34 PM
1988_96hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr &raquo;</TD></TR><TR><TD CLASS="quote">you may have put the dizzy 180 degrees off on the timing. the plugs aren't fireing when they are supposed to. what is the car?</TD></TR></TABLE>
corect me if im wrong but ive never seen a honda dizzy that could be but on 180 degrees off, i thought they were all offset to prevent that
98jdmek
Nov 29, 2007 11:35 AM
myhondasux
Nov 30, 2006 08:48 AM
illagee
Dec 2, 2005 08:59 AM
vxnine
Jul 25, 2005 03:20 PM
NorcalHB94
Apr 28, 2005 09:54 PM
