JDM B20b - won't start - what am i missing?
Got spark, got fuel, compression good, thermostat ground valve cover ground, and tranny ground all hooked up.
OBD1 LS Injectors - B20 basemap in a p72 w-hondata (doing a B16 head by spring)
Only things changed since I pulled the LS are injectors (was using DSM450's with resistor box (I removed the box and spliced all 5 wires together)
And the ECU (was using a LS chipped ecu)
And changed over to an H22 throttle body w/ map sensor. (removed the EVAP canister and the old map and purge solenoids)
What the hell am I missing?
Its cold and late!
Its cold and late!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC_jdm_da9 »</TD></TR><TR><TD CLASS="quote">look at ur dizzy....</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot »</TD></TR><TR><TD CLASS="quote">battery wasnt listed.....lol</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">is there any power at all when you turn the key?</TD></TR></TABLE>
Turns over fine - has spark and fuel!
What should I look for at the dizzy?
What about the FPR? How do I adjust it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic »</TD></TR><TR><TD CLASS="quote">Timing is fine - it has to be an injector or map issue.
Anyone know the injector wore colors?</TD></TR></TABLE>
I double checked my injector wire colors and they are correct as well as the firing order.
I am thinking my map is no good!
Honda_Fanatic
Nov 29, 2007 08:23 AM
B18 CYA
Sep 12, 2006 02:42 PM
BuLLDoGG
13
Aug 24, 2005 08:41 PM
