THIS IS RIDICULOUS
Old Nov 28, 2007 | 12:08 PM
neophyte210's Avatar
Default THIS IS RIDICULOUS
my engine builder finished my motor. 2 days later i put it in my car with a new rebuilt itr tranny after about 20 seconds of running it starts leaking motor oil from what looks like rear main and from the oil pump .... right underneath the o-ring.. so i pull the motor honda-bond everything stick it back and and still same problem.... all the seals in the motor are brand new honda ... i did notice however that on the block where the rear main plate bolts to and on oil pump side whiere it bolts to that there are scuffs like somebody has sanded it or something ... maybe it's uneven... even then with the hondabond and the fact that its aluminum it would still seal but i guess not .... its coming out again tomm but then what?
Old Nov 28, 2007 | 12:26 PM
hybrid_KJ's Avatar
Default Re: THIS IS RIDICULOUS (neophyte210)
Did you check the main oil galley plugs. Right above both the oil pump and the rear main seal plate there are two large plugs with a 14mm allen. Check and see if those are tight and if they need new crush washers and/or thread seal.
Old Nov 28, 2007 | 02:00 PM
Default Re: THIS IS RIDICULOUS (hybrid_KJ)
thats a good point i didn't even look at that ... the block was stripped so that is very plausible ... thanks for the insight
Old Nov 29, 2007 | 09:15 AM
no other ideas?
Old Nov 30, 2007 | 05:14 AM
any other insight's motor comes out again tomm ..... is there anything on the driverside that would leak oil under pressure other than the oil pump? cam seals aren't leaking
Old Nov 30, 2007 | 05:56 AM
hybrid_KJ's Avatar
Also check the rocker arm shaft plugs on the timing belt side.
Old Nov 30, 2007 | 08:13 AM
Rickdrizzle's Avatar
THIS IS MADNESS!
http://youtube.com/watch?v=rZBA0SKmQy8
Old Nov 30, 2007 | 09:06 AM
Default Re: (Rickdrizzle)
yeah well i wouldn't expect you to know
just wondering if theres anything else i should check while motor is out before it goes in again, and waste more time
Old Dec 2, 2007 | 12:35 AM
onepoint6i's Avatar
Default Re: (neophyte210)
hows the pcv system? i hope your engine is breathing properly....??
Old Dec 2, 2007 | 03:55 PM
Hybrid96EK's Avatar
Default Re: (onepoint6i)
My first vote would be someone over torqued the oil pan and warped it. Now its not sealing.
Old Dec 2, 2007 | 04:12 PM
Fat Chick Magnet's Avatar
take the motor back to him and tell him to fix it. what kind of a engine builder is that..
Old Dec 2, 2007 | 04:42 PM
Default Re: (Fat Chick Magnet)
put motor back in today and thanks hybrid_KJ the allen plugs were the problem ... they were only finger tight .....
Old Dec 2, 2007 | 04:48 PM
all-mtr-teg's Avatar
damn, so you pulled the whole motor out?
Old Dec 4, 2007 | 04:53 AM
Default Re: (all-mtr-teg)
ya like 3 times
AlfieRoach
May 30, 2011 01:20 PM
dohcdelsol
Jan 21, 2007 06:37 PM
adseguy
Jul 8, 2006 11:09 AM
beerz
Acura TL, RL & ZDX
Nov 4, 2004 11:59 PM
beerz
Sep 16, 2004 04:11 AM
