sohc engine builders, oil pump and rear main seal gaskets
Im building a sohc z6 motor and its time to finish the bottom end. i jsut have to put the oil pump on and the rear main seal on. the unit of each. Is there a specific gasket that goes inbetween the oil pump and the block or should i use hondabond ht? same with the rear main seal side.
any and all imput welcomed.
Re: sohc engine builders, oil pump and rear main seal gaskets (dohcdelsol)
I do the same..
I reused the original joint ring. and I add sealing paste...
It looks fine... But I haven't got oil pressure when the oil is warm.. This problem was detected before the oil pump removed.. So not the ring is the problem...
Re: sohc engine builders, oil pump and rear main seal gaskets (BoosteD14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoosteD14 »</TD></TR><TR><TD CLASS="quote">I do the same..
It looks fine... But I haven't got oil pressure when the oil is warm.. This problem was detected before the oil pump removed.. So not the ring is the problem...</TD></TR></TABLE>
what joint ring???
huh?
what joint ring???
huh?
The rear main seal is just drifted in no need for any kind of sealent on it. I used a large socket and hammer a little tappy tappy tappy and it went into place.
Hondabond between the machined faces of the oil pump, the rear main seal bracket, and the block. Don't forget the o-ring for the oil pump discharge.
